  • July 12, 2025, 05:44:15 PM
Author Topic: ST 46 Wrist Pin Access Plug Thread Size  (Read 1738 times)
Offline Dick Pacini
« on: May 14, 2013, 09:33:37 PM »
Does anyone know the thread size of the tapped hole in the rear of the cylinder casting on a ST 46?
AMA 62221
Offline Bootlegger
Re: ST 46 Wrist Pin Access Plug Thread Size
« Reply #1 on: May 16, 2013, 05:14:53 AM »
 Dick, I sent ya' a P M  good luck...
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #2 on: May 16, 2013, 05:59:12 AM »
I have seen many that the bolt is missing and they seem to run normal.Must be that they don't leak with it missing.
Offline Andrew Tinsley
« Reply #3 on: May 16, 2013, 02:10:59 PM »
I don't have an ST46, but I thought thethreaded hole had something to do with pushing out the wrist pin. I may well be wrong on this and goodness knows where the pin would go.
  perhaps someone would tell me if I am right or not!
Andrew.
BMFA Number 64862
« Reply #4 on: May 16, 2013, 03:57:13 PM »
Andrew.
Hi Andrew,
The hole is for the wrist pin removal, but you do not "push" it out, you PULL it out.  I have used a needle from the ST NVA to thread in the hole in the wrist pin.
« Reply #5 on: May 17, 2013, 04:48:51 AM »
Thanks Bill!
It all makes sense now. Amazing how you can go for years with the wrong idea!
Andrew.
BMFA Number 64862
« Reply #6 on: May 17, 2013, 06:11:57 AM »
If you see a ST/40-46 with a hole in the front directly opposite the rear hole then some one has drilled it to push the pin out. If the pin is frozen to the piston this method will work. A 1/8" hole will work so a drift punch will fin in. Be careful to not pull the sleeve out all the way as it is needed to support the piston. If they leak,tap it and put in a bolt and grind it flat inside or just JBWeld it.
