Funny you should mention an LA-46 mysteriously going fat.... I had trouble with that very problem yesterday......
Mine has not been going dead rich, but just fading a little bit rich off the takeoff needle setting the last few weeks. Since the airplane was marginal on power already, any loss late in the pattern was critical, and eventually fatal.
I tried to fool the engine yesterday by switching the tank venting from uniflo to standard venting, which reduced but did not eliminate RPM drop off and ultimately didn't work.
My engine was a moderately well used motor from another airplane, with approx 280 flights. I do consider John Tates comment on this isue on the SSW version of this thread to be intriguing. When I put this motor into the Avanti, I pulled the head off to add a shim and was suprised greatly to see the glo plug almost completely obscured with some sort of sintered on looking dark material. Presumably carbon, but I've never seen a carbon deposit that big in so few flights, or piled on the top of the plug like that. I wonder if my liner was shedding nickel. I looked at the liner and saw no obviously peeled areas, but when you shine a light on the liner, from certain angles the silvery looking nickel seems almost translucent and the liner has a brassy tinge to it. I haven't taken enough LAs apart though-maybe they all look like that. Tates engine he mentioned in the other thread had an out of round condition from the factory and grenaded the P/L in only about 30 flights, so that was a different case.
Liner issues (or not) aside, hopefully there are some ideas to fix this problem when it does occur. My problem was much more subtle then going dead rich, but just as annoying and puzzling to figure out.
