Hi guys,
Some one please help me with the tank set up for my Score. The fuse is covered/doped, the bottom tank hatch cover not yet glued in place.
I will be using an ST 51 so will need 5.5 to 6 oz. of fuel. I would really like to use a metal tank and seal it in the fuse, never to be seen again. Probably not practical, at least until I have the tank height question answered.
I have been using metal uni-flow tanks, but have grown weary of the rich/lean problem when flying upwind/downwind. So, thinking about a straight suction set-up. With the suction set-up, how could I install plumbing so that both the fill line and the over flow line would exit the bottom of the fuse--will that even work?
I want to epoxy the tank hatch cover in place to gain a little strength in the nose, so would like to use a metal tank, but will use a plastic tank if necessary.
Help, please!!
Jim
