  • June 19, 2025, 10:50:06 PM
Author Topic: ST46 Venturi  (Read 3082 times)
Offline Tom Dugan
ST46 Venturi
« on: April 08, 2006, 08:15:40 PM »
I just received 2 ST46 engines back from rebuild by Frank Bowman.  He did an awesome job and over time I will send all my STs to him.
The question I have is that I now need Venturis and NVA for them.  I have looked around and know that there are two types available for the ST, a true/sprinkler and the restrictor/center type.  Also, there are aluminum and delrin venturis.  Is there an advantage of one over the other?
I also want to ask if it would be wise to have several different intake diameters for tuning purposes when I eventually place these in planes?
Thomas
Re: ST46 Venturi
« Reply #1 on: April 09, 2006, 01:00:27 PM »
Hi Thomas,
Our "Engine set ups" forum moderator, Randy Smith, can hook you up with the necessary correct parts real quick.
