I can comment a bit about the LA-46 stuff, but ST-46s are before my time and I have barely even seen any fly, except for Bill's that did indeed melt down when it tried to turn 11,000 (!)
I would classify the LA as *pretty* good up to airplanes in the approx 50 ounce range, based on my experiences with them. I ran my "good LA" for 250 flights in a 50 ounce Time machine 50 running the APC 12.25x3.75 cut down to 11.75", then later a Gator 10.75x3.75 three blade and Bolly 11x4 N three blade. The engine was pretty good in that it "homed" on the RPM it like to run at (about 10350 ground launch) in the air and was pretty repeatable. %5 Nitro in the winter and 10% in summer, no big deal. I would characterize the overall performance of the plane as pretty good, and the plane scored three or four Advanced victories and a number of podium finishes.
This past summer when I put the same engine in the Avanti 50 (thicker wing, 600sq vs 580, 54 ounces ), I noticed I couldn't seem to prop it with anything that made it happy. Virtually every prop I tried (APC 12.25x3.75, Bolly 11x4 3bld, Gator 10.75x3.75 3bld, APC 11x5, APC 11.5x4, Rev-up 12x5), and on fuel up to 15% nitro, launching at 11,400 RPM, the engine seemed to "home" to the same (lower) RPM it liked to run on the other airplane,- which was not the direction I needed the power to go, seemed to fade fractionally later in the tank, lacked vertical drive in the power maneuvers, had to be flown quick, 4.7 to 5.0 laps to have enough energy for stuff like the square 8, and had considerable windup in even a moderate breeze, and absolutely no braking on the backsides of maneuvers. Adding pitch (like the 11x5 or 12x5), made it take off like a rocket every time a puff of wind got it, but seemed to give minimal help for the vertical punch or drive. Maneuvers like the overhead 8 or clover could be a chore, and trimming the plane completely was difficult when chasing power. The one thing I didn't do, and should have, was go much bigger on the venturi then the .285 already in it. The plane was lost and the motor killed before I got around to it.
The guys around here talk about flying 55-58 ounce airplanes on the ST-46; from my point of view, I wouldn't try that around here with an LA unless I put a big venturi on it and a pretty open exhaust system. But even then, the lack of brake on the backsides would still be annoying. If I had to do the project again, with an inexpensive motor, I would go the ST-51 route. I've seen alot of those fly, and at least in these parts they seem to give a better stunt run, and can easily fly a bigger plane than the LA. In stock format the LAs run great on smaller, lighter planes, you see mobs of profile Cardinals, etc with the motors. But my experience leads me to conclude 50+ ounces and thick wings might require some development to get the right kind of output you need....
