I have a McCoy Redhead 35 that was frozen with Castor oil. I have freed everything up except the wristpin & connecting rod. I have tried a little heat with no luck. It has soaked in carb cleaner(out of the spray can, Autozone) for two days, with no luck.
What should I try next?
