  • June 22, 2025, 11:09:50 AM
Author Topic: Spraybar for OS fp40  (Read 2267 times)
« on: March 08, 2014, 11:17:52 PM »
I have an fp40 to use in my Oriental when it's finished in a couple of months, but the spraybar is bent. Where should I shop for an OEM spraybar? The needle looks straight, but if a needle isn't part of the package, I should get one too.
Thanks.
Rusty
Offline Fredvon4
  • Central Texas
Fred von Gortler IV
Offline Geoff Goodworth
Re: Spraybar for OS fp40
« Reply #2 on: March 09, 2014, 05:46:52 PM »
OS Part No 2231 1000 the full needle valve and spray bar assembly. Tower has them for $13.49 each with quantity discount.
« Reply #3 on: March 09, 2014, 07:01:38 PM »
Bookmarked. Thanks Fred and Geoff.
« Reply #4 on: March 09, 2014, 08:54:42 PM »
Hi Ty. Are there some modifications I need to do to make it fit? Just curious, not shying away, as I'm capable of that sort of thing. What sort of "better" would I see from Randy's; more accurate settings, holding a setting more reliably, etc? I'm all for that. It's enough learning to stunt consistently without having to unnecessarily fiddle, guess, and hope with an engine. So far I really do like the two FPs I'm flying, a 35 and a 40. And I also have an fp 25 for the Skyray I'm building, but it has an RC carb. I'll address that when the time comes, probably in a few weeks.
Rusty
Offline Akihiro Danjo
« Reply #5 on: March 10, 2014, 12:50:55 AM »
Rusty san.
You have to enlarge the bore of the venturi when using ST or PA NVA.
There are some various venturi bore of stock OS venturi, and so please check yours.
I do not have OS FP40 but I think you will be able to find good setting between 7.0mm to 7.4mm with ST or PA NVA. I use 7.1 to 7.3mm venturi for my Tower 40.
Good flying, Aki
« Reply #6 on: March 10, 2014, 05:36:06 AM »
Good point Aki.
The large venturi sold by Tower for the LA 46 is 7.1 mm. Also, for reference, the PA, ST and Brodak NVAs are all 4mm dia while the factory OS assembly is 3.5mm dia.
« Reply #7 on: March 10, 2014, 10:26:47 AM »
Thanks for telling me about this. Since I'm still in the Beginner stunt stage, and not competing with this Oriental yet, I think I'll go with the OEM direct replacement at least for now.
Rusty
« Reply #8 on: March 10, 2014, 10:51:29 AM »
Rusty
Hi Rusty,
For now, the OEM part might be best.  The needle has a spring arm instead of being a solid bar.  If the model ever hits terra firma inverted, the spring usually bends where the solid needle will break.  No change to the case to install, etc..  After a while, the PA NVA will become desirable. ;D
BIG Bear
RNMM/AMM
Offline Jim Thomerson
« Reply #9 on: March 10, 2014, 12:43:38 PM »
I run mostly Super Tigre NVAs.  They are not perfect, but I have used them since 1978, and understand how to make them work to suit me.
« Reply #10 on: March 10, 2014, 02:35:12 PM »
Hi Rusty,
BIG Bear
RNMM/AMM
I agree, Bill.
Back in July when I first began learning PA, one lesson dogged me, and I finally learned almost too late, just get an engine run that I can work with, fly and concentrate on the pattern. I wasted so many practices fiddling with all the complicated things I read the "experts" and experts talking about. Much of which will matter, but not until I get there. I ain't there yet. But I can chuck an off the shelf NV in the engine and fly without busting a short pattern, and then some if I treat myself to a bit of extra fuel.
Rusty
Offline Fredvon4
  • Central Texas
« Reply #11 on: March 12, 2014, 09:08:24 AM »
Another vote for the PA NVA, I got three from Randy and they are first rate well made product that is worth the bucks
I have them on Fox Mark series combat engines and really like them a lot
Fred von Gortler IV
« Reply #12 on: March 12, 2014, 09:19:26 AM »
When I'm ready to press that engine into service, I'll PM Randy and get the lowdown on it. Thanks for the replies.
Rusty
« Reply #13 on: March 12, 2014, 10:56:21 AM »
Rusty
   There's nothing wrong with the stock needle/spraybar, and there is no doubt that using the bigger PA/ST type is reducing the choke area. The OS is probably quite preferable to the original ST needles, because it supports the tapered part of the needle better, so it doesn't buzz itself up like a tuning fork. The PA (and Jett) needles don't have that problem, of course.
I actually like "clicky" needle valves, it keeps you from fooling yourself into making too small a change.
