  • June 19, 2025, 04:53:55 PM
Author Topic: 11x4 on O S 32  (Read 1395 times)
Offline Bootlegger
11x4 on O S 32
« on: June 07, 2018, 08:26:29 AM »
  Will an O S 32 turn an 11x4 A P C prop alright?  I am trying to get a little more bite, and load the engine  some what.  Thanks
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: 11x4 on O S 32
« Reply #1 on: June 07, 2018, 11:21:38 AM »
OS 32 what?  And what are you using now?  And for what?  For stunt, I suspect that a 32AX would do somewhere between OK and fantastic on that prop, but I haven't tried it.  The biggest issue I'd look for is the engine wanting to run away, because the AX line seems to be tuned for higher speed than the LA and FP lines.
Offline Bootlegger
Re: 11x4 on O S 32
« Reply #2 on: June 07, 2018, 12:43:55 PM »
   Sorry about the error, it is an S X or F  don't remember which, but I do thank you for your response..
Gil Causey
AMA# 6964
Re: 11x4 on O S 32
« Reply #3 on: June 07, 2018, 01:27:25 PM »
All of those  will turn a  11 x 4, and that is very close  to what you want, if it is an  older  OS 32 F  or  H  you may want to try a  TT 11 x 4.5
Offline GERALD WIMMER
    • Auckland Free Flight Club
Re: 11x4 on O S 32
« Reply #4 on: June 07, 2018, 03:21:28 PM »
Hello From reading the OS literature I believed the AX line were a more torquey engine as the recommended prop fro a AX 35 goes up to a 12x6 and for the AX55 they recommend up to 13x7 . Presumed these large props are to reduce noise on RC models . Having never tried an AX but curious how this new generation runs are the engines going to be hot and unhappy on big props or does all that extra fining and weight count for something?
http://downloads.hobbico.com/factsheets/osm/osmg0545-fact-sheet.pdf
Regards Gerald  :)
Re: 11x4 on O S 32
« Reply #5 on: June 07, 2018, 04:04:37 PM »
Regards Gerald  :)
Hi  Gerald
he s asking about a  Control Line  setup, and you would never run one of those sizes on the  32 for  CL, I do not  even think the  Os 32F would be at all happy on a  12x6
Re: 11x4 on O S 32
« Reply #6 on: June 07, 2018, 07:23:08 PM »
     That doesn't seem like a lot of load to me (that's about where I would start), but only one way to find out.
    People underestimate how much power is available from these engines, I have seen people run 10-4 3-blades on 20FPs, and it ran fine and flew the airplane OK. It did get rather hot, though.
