CLICK HERE--><--CLICK HERE
Small engines and how to set needles
Started by Brett Buck, September 01, 2026, 03:32:07 PM
Previous topic - Next topic
0 Members and 2 Guests are viewing this topic.
Colin McRae
Quote from: Brett Buck on September 28, 2026, 04:47:54 PMNote that this was not the proper needle!
Why???
Bob Brooks sells 2 styles of NVA's specific for OS LA/FP engines. On both, the spray bar is the OS stock diameter size at 3.5mm. My case is NOT drilled out for a 4mm spray bar. They are OS LA/FP direct fits.
The only real difference between the 2 he sells is one has the 'spring' type needle, and the other a rigid needle he calls a Super Tigre 'type' needle.
https://www.ebay.com/itm/294513244851?itmmeta=01M3N7MGAGQ4NQS2KWYYV6VN1G&hash=item44925b7ab3:g:F3wAAOSw9BlhcyUs
Colin
Brett Buck
Quote from: Colin McRae on September 28, 2026, 05:00:10 PMWhy???
   The click needle is superior to the ST-clones. The needle is supported better instead of the fairly-well-known "tuning fork" ST type. But most importantly, you can easily be fooled into making too small an adjustment because you don't have any references.  You have to take tools to the engine to install it, and you don't need tools to make the engine run, aside from a JIS #1 screwdriver.
  I am not the needle valve police, anyone can use whatever they want. But, again *that is not what came in the box* and I don't want anyone confused, yet again, about what the stock configuration might be, and them come bitching at me about my bad advice.
Colin McRae
#27
Quote from: Brett Buck on September 28, 2026, 05:16:53 PMThe click needle is superior to the ST-clones. The needle is supported better instead of the fairly-well-known "tuning fork" ST type. But most importantly, you can easily be fooled into making too small an adjustment because you don't have any references.  You have to take tools to the engine to install it, and you don't need tools to make the engine run, aside from a JIS #1 screwdriver.
There are always pros and cons with this hobby of ours.
What 'came in the LA box' was a rear NVA. Standard front NVA's are better IMO. Hard to find OS stock front NVA's in todays world.
I would prefer the click type too if OS stock front NVA's were readily available. The click type that Brooks offers has a somewhat long spring that can vibrate excessively. It is quite a bit longer than an OS stock front NVA. So, I prefer the ST type. With appropriate patience, the ST type needle setting can be tweaked as needed.
Colin
Brett Buck
#28
Quote from: Colin McRae on September 28, 2026, 05:33:54 PMThere are always pros and cons with this hobby of ours.
  The stock LA arrangement is perfectly fine, functionally. They are prone to breaking in a crash. And this spraybar assembly, from the same source, has both clicks and supports the needle properly:
https://www.ebay.com/itm/293139719059?_skw=os+fp+needle+valve&itmmeta=01M3NJJDXNK94D3BWG19280FFV&hash=item44407d2393:g:M8sAAOSw5eBcolX7
And you can still get the original OS version:
https://www.ebay.com/itm/147272251877?_skw=OS+FP+needle+valve+assembly&itmmeta=01M3NJB95C81VQD2KMH6K3KGAM&hash=item224a1c39e5:g:0MEAAeSwaENp59Dv&itmprp=enc%3AAQALAAAA4GfYFPkwiKCW4ZNSs2u11xC4yZk7NomYV0IssmcZs%2FHrtpSxdX%2Biq7TQMXO5o7kLg7G0zKgpeJUfrZjy2a%2B%2FW%2BdVhiz%2FLgFKuCULPuUJCxRQpZHeGi8fVF%2FcXiox8esxHYM3du93CvzmLiQxc7cq6oNlkCvALCxqKgD12%2BZVJFv4QEONnujc9vhHXpWHykM%2BSTcuznt5fW%2FFUIlCRQhX9a2H3JPx%2FGO7tnNUVWQMdM0Z5NolBTv6eVuXUS5W31psBlMwsHuluhNzz7S8iRjc4fcY%2BMjlUjszjzHvmbFsVRFt%7Ctkp%3ABk9SR_CSrbKdaA
   Again, I was trying to point out that your engine had been modified, so no one would get confused - again.
p.s. I know this sounds very pedantic, but over and over and over again, *you do not need to modify your engine* or take tools to it. I am trying to offer the best possible advice, but I have seen for years that it just doesn't make any difference. People are going to do what they do, and I am not the engine cops. But we just had a very long thread where we went from failure to success by putting everything back the way it came - and it is hardly the first example.
   If everyone absolutely insists on using the ST-type spraybar (note, it is not an ST needle, it is a copy - check the hex measurements), *at the very least*, get it close and then screw the collet down as tight as you can safely get it and still be able to make very small adjustments you need from day to day. The reason is as Big Jim Greenaway discovered in the late70's - since the needle is supported only at the "pinch" end of the collet, and the threads are pretty loose, the needle is effectively cantilevered from the pinch to the pointy end. Every now and then, you will hit the natural frequency or some harmonic of this tuned system, and then you will get completely unexpected brief mixture changes or "funny" rich/lean transients. The big improvement with the PA and Jett assemblies  is that instead of a pinch collet, it has a teflon compression fitting, which  seals better on the threads (PA) and infinitely better on the smooth part of the shaft (Jett) and also provides a lot of damping to minimize this issue while still allowing you to turn it easily. The thread fit class is much tighter, too. Of course, you shouldn't use that on your FP *because it is the wrong size(, and we are back to drilling.
   The OS spraybar and needle has a tight slip-fit which supports the needle until the start of the taper, and the needle itself is thicker with a much stiffer end. The threads are on the outside. This prevents the ST-type tuning fork problem. The click adjustments are just a bonus (and I won't mention another possible modification to it...). I would *much prefer* to have an OS-style system on the Jett, although I have only ever had one actual problem with the Jett arrangement and that was a long time ago.
   These details are the sorts of things that really matter in stunt, the ST needle thing formerly drove many people to distraction chasing off into the weeds looking for silly "fixes" until Jim figured it out. We used ST needles (then easily available anywhere) for some of the early experiments, too, and had occasional issues with it despite knowing to crank down on the collet (and to use Harry Higley needles).
