  • May 01, 2024, 04:49:33 AM
Author Topic: Prop size and timing  (Read 885 times)
Offline Terry Caron
« on: March 04, 2017, 02:28:19 PM »
What effect, if any, does prop size have on timing?
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Re: Prop size and timing
« Reply #1 on: March 04, 2017, 03:22:54 PM »
   Timing of what?
Offline Terry Caron
« Reply #2 on: March 04, 2017, 03:27:27 PM »
Ignition.
AMA 249824
NRA Life Member
Offline Terry Caron
« Reply #3 on: March 06, 2017, 02:17:15 PM »
Well, good thing I clarified that.  ;D
Anyhoo, the question arises due to a situation I encountered while bench running an O&R .60 S/P on glow, recently resurrected from parts engines.
It would start easily enough but would run ONLY backwards.
Running straight meth/castor and with no compression adjustment possible, I vaguely remembered reading something about prop size affecting timing so I wanted to clarify the relationship, as even a 14" prop made no difference.
However, in the event it turns out to be a non-issue, as I found my field box battery to have low voltage.
After overnight charging, the engine fires up very easily and runs normally.
It certainly seems counter-intuitive, so any thoughts on low voltage causing a pseudo-advanced condition?
AMA 249824
NRA Life Member
