  • June 17, 2025, 09:28:03 PM
Author Topic: OS FP .40 Engine Conversion  (Read 3330 times)
Offline Steve Dwyer
« on: March 08, 2016, 08:22:43 PM »
I want to use an OS FP .40 on the Primary Force I am building, unfortunately they seem scarce except for the RC types. Does anyone have experience converting an RC to a control line? It looks like I can still get FP .40 parts from OS. Is it as simple as ordering a needle valve and venturi? I read something where a shim gasket must be installed under the head to achieve control line performance? Is this a fool proof sure fired conversion or should I expect to have problems down the road?   If it will work can you outline the exact parts and the best source to make this happen.
Re: OS FP .40 Engine Conversion
« Reply #1 on: March 08, 2016, 09:17:30 PM »
I have done hundreds  of them, you can just convert it, if you want, by using a 240 to 250 venturie and the OS  NVA from the 20,  or  use a 265 to 280 venturie and a  ST or PA NVA.
The OS assembly is very thin, so it makes the size conversion  wrong for most people, as it acts much bigger than people think it will,  This was the main reason for the runaway problem that started with the FP 35 40 series.
Offline Target
  • C/L Addict
« Reply #2 on: March 08, 2016, 09:58:31 PM »
I'm running a .250 venturi in mine, and an added head gasket/shim, to lower the compression a tad.
My engine masseuse also massaged the port timing, but he says that doing that is optional, and that the above two mods alone will make the FP tame.
Mine starts real easy, and does a perfect 4-2-4 break.
We run 5-10% nitro, and I'm using a 10x5 Master Airscrew WOOD prop on this engine on my Banshee.
It's a sweet setup!
R,
Chris
Chris
AMA 5956
Offline Geoff Goodworth
« Reply #3 on: March 09, 2016, 10:15:26 PM »
Steve, while not in the business like Randy, I've converted quite a few.
I'm quite happy with the OS NVA Part no. 22311000. It makes the conversion a straight bolt up.  Others prefer the infinite adjustment available with the ST NVAs. However, using an ST NVA requires the crankcase and venturi be drilled out to accept the 4mm OD NVA (the OS part is 3.5mm as are the screws that hold the carb).
For a Primary Force, I'd start with the FP 20/25 venturi OS Part No. 22312000 (6.55mm ID). The now discontinued small venturi that used to be supplied with the FP 35 and 40 is 6.75mm ID (17/64"). You might like to consider buying two FP 20/25 venturis and drilling or reaming one out. Just for reference, the venturi currently available for the FP 40/LA 46 is the large venturi from back in the day when there were two.
Thr FP 40 that I'm currently flying in a Profile Cardinal has a Bob Zambelli hemi head and a 6.75mm venturi. The model is 51 oz and I'm using a Bolly Clubman 10.5 x 5 prop.
« Reply #4 on: March 09, 2016, 10:51:23 PM »
My buddy flies a primary Force he built in 2001 from Mike Pratt's plans, and it flat out hauls ass with an LA25. It's in the 30something ounce range, so a 40 would be way too big for it. But maybe the ones he sells now are heavier? An fp40 will haul a lot of plane.
Bob Z. is doing a hemi job on the fp40 head in my Oriental. It also weighs 51 ounces and the engine was running really well, but one day decided to start running away. That was after repairs added weight to the airframe. But yeah, lowering the compression is a big help with taming that engine. Better than stacking gaskets. Mine has the NV and small venturi from an fp25.
Rusty
« Reply #5 on: March 10, 2016, 10:48:31 AM »
I have an OS .40FP that I bought used 20 years ago from the late Byron Barker.  This has been one of the best .40 size "normal" engines I have had!  I have used it on numerous profiles and two built up models.  Always done a great job and got Aaron from beginner to Intermediate then Advanced!
Wish I had a couple more like this one.......
BIG Bear
RNMM/AMM
