  • July 08, 2025, 09:18:31 PM
Author Topic: shrinking a cylinder liner by squeezing the circumferance ?  (Read 1253 times)
Offline gwassenaar
Some time ago I read an article by some one who saved clapped out liners by pressure squeezing the circumferance of a liner. Any body remeber this ?
Re: shrinking a cylinder liner by squeezing the circumferance ?
« Reply #1 on: July 25, 2019, 09:50:21 AM »
   I have heard of RC car guys doing something like that. I can't say I see any horrible problem with doing something like that, if done as they do (with a carefully-machined clamp for .0005" inch or so (which is all it should take)).  Knowing stunt guys, no, you can't use vice-grips!
     In any case, if it's worn out, you have nothing to lose.
    I haven't known of anyone doing it to a stunt engine. Its also nearly impossible to wear out an AAC/ABC/ABN piston/liner in stunt, anyway, so you are likely to move on to the next big thing before you have to worry about it.
Offline George Truett
« Reply #2 on: July 25, 2019, 10:00:35 AM »
It exists; https://rcrenew.com/  I would have to be desperate to try that.
Tags: shrink dimish squeeze
