  • June 20, 2025, 01:03:47 AM
Author Topic: Leo 46 : O.K for Stunt ?  (Read 1168 times)
Offline Robin_Holden
« on: September 22, 2010, 10:11:16 AM »
Greetings all from a sunny Charente.
Has anyone tried the Leo 46. This is the Taiwanese OS clone.
Would it make a reasonable stunt engine , or does it need Randy's magic ?
Why do I ask ? I shop with hobbycity.com in Hong Kong now and again.They're a reliable supplier I've found.
Leo 46's are up for U.S $ 46.95 plus shipping [ around $14.95 I think ].
They've got ASP [ like the Magnum ] engines as well.
Would appreciate any experience anyone has had ,
Kind Regards ,
Robin.
Offline Scott B. Riese
  • Just a student of stunt
Re: Leo 46 : O.K for Stunt ?
« Reply #1 on: September 27, 2010, 10:53:41 PM »
Robin. There a engine that wants to run at a high RPM and use a low pitched prop. 12.5x3.8 APC at 10300 would be a good starting point. ALSO ADD a head gasket .005 use a hot plug. Low Nitro (5%)with 50-50 18% oil with TWO-Four ounces of Castor added per gallon. The muffler is the question. I used the Mac's Black MINI PIPE...works very well. Other then that I ran that engine about 50 times and was offered $$$ so I got rid of it. IT WORKED! I used the other smaller leo 34 in my profile cardinal, and I use an leo 15 for clown racing
Scott Riese
Portland, Oregon
AMA 528301
« Reply #2 on: September 28, 2010, 12:28:03 AM »
Scott , very much obliged for your very detailed post.....
Thanks ,
Robin.
Offline Gary Anderson
« Reply #3 on: October 03, 2010, 11:27:36 PM »
Hi Robin,
I have a Leo 46 that was given to me. I believe its very close to being the same engine as a OS46SF. The venturi is very small on the leo and seems to work okay, (never checked the size of it) the engine is okay, runs well but not as well as a good old LA46. I don't believe anyone has tried this engine on a pipe, might just be a winner with that type of set up. Mine will 4/2/4 but it really like to run hard, which isn't really good for stunt. Mine is build very well and isn't junk but again the OS 46 LA is a better motor for stunt??? Got to remember what works well for one doesn't mean it would work well for you. If ya get it, play with it and let us know how she worked out for you. I also found that my Leo like 5% or 0% better than 10%. Mine swings a 12/6 apc prop and doesn't miss a beat and she is flying a sixty size ship with out a problem??? Good luck, Gary
Gary Anderson
« Reply #4 on: October 03, 2010, 11:58:25 PM »
Gary , much obliged. Really appreciate your input.
Regards ,
Robin.
Offline Michael Boucher
« Reply #5 on: October 07, 2010, 01:15:05 PM »
Hi Scott, How did you set up your LEO 34? Do you like that engine?  Thanks, Mike  ???
AMA 59633
