  • July 17, 2025, 12:12:37 PM
Author Topic: Shark 45 and Irvine .46  (Read 4228 times)
Offline Greg Hart
« on: April 04, 2006, 04:11:01 AM »
Anyone know if this combination is doable. A Shark 45 with a Byron Barkers worked Hemi Head Irvine .46. Not sure of the dia of the large black venturi he made for it. The NVA took 18 full turns to get it opened enough to start it. Ran it according to the break-in instruction. Sweet running sounding engine.  Thanks for any input.
BUY A UKEY AND LEARN
Re: Shark 45 and Irvine .46
« Reply #1 on: April 04, 2006, 07:40:38 AM »
Hi Greg,
Since the original Shark 45 was flown with the K&B 45, I would think that a resonably built Shark 45 would be just fine with the 46.  It HAS to have more power and less vibration than the old K&B!  8)
Offline Greg Hart
« Reply #2 on: April 09, 2006, 12:52:10 AM »
I was told to get rid of the Irvine and get a OS.46
Would you?
« Reply #3 on: April 09, 2006, 02:37:20 AM »
Would you?
Maybe I would because the OS 46LA is so popular and the set ups are out there readily available with many people to help out.  Can't say as to the relative power in a comparison.   My fist inclination is that the Irvine might have the edge there.  I haven't seen the 46LA exhibit the power of a ST G51, which is also readily available, popular in use, and can be had for about the same price as a 46LA.
I would go with the ST G51 hands down in a Shark 45 if you had the opprotunity to get one.  Even better if its reworked by Randy Smith,  Tom Lay, or Byron.
Those examples have been very strong whe I have used them.  A definite improvement over stock, which is still a very good, strong, stunt engine..
But like I said to start with, the Irvine shuld power the Shark 45.  I have several engines set up by Byron.  All have been very user friendly and performed excellently.
  Didn't know there were options!  ;D
« Reply #4 on: April 11, 2006, 11:11:37 AM »
Greg,
I'd stick with the Irvine if set up by Barker. I've been told they are very good engines. Just build the plane reasonably light. Should have plenty of power.
Offline Charlie Pate
« Reply #5 on: April 13, 2006, 07:44:55 PM »
Why not check with Byron?
He was still alive (last time I saw him )and should be able to help you with the set up.
I have always found him to go the extra mile to help.
Give him a call or Email.
My Motto:
Check with the guy that built it; Then do EXactly as his says.
 y1
« Reply #6 on: April 16, 2006, 11:30:34 AM »
My Motto:
 y1
Ah.....Grasshoppa..........
You have been around the Evil Busby, no?
 j1
Actually that is the exact advice that should be given.  Check with Byron!  Great guy.
