  • June 17, 2025, 09:36:53 PM
Author Topic: Can anybody identify....  (Read 3920 times)
Offline Gerald Arana
« on: June 22, 2017, 07:58:56 PM »
This ABC P/L is from an estate and I want to know what it is for. The bore is .801-.803 and about 1-1/8" long as best as i can measure it. It looks new to me.
Thank you, Jerry
Offline Gary Dowler
Re: Can anybody identify....
« Reply #1 on: June 22, 2017, 09:54:35 PM »
Others will doubtless know more, but the big slightly squared head makes me think of a car engine.  The bore size you mention says its a big motor!
« Reply #2 on: June 23, 2017, 07:36:09 PM »
This the head , magnum maybe being ABC not ABN ?/
http://shop.rotor.com.sg/images/Product/17532/size.gif
« Reply #3 on: June 23, 2017, 10:01:10 PM »
Thank you, Jerry
It looks like a Magnum 36 XL ll  sleeve and head, the  36  is .807 bore  , with the short throw, has a  short sleeeve
it is a true chrome engine, but your  set is missing  the piston
« Reply #4 on: June 24, 2017, 10:32:34 AM »
Thanks guys. I know its missing the piston!  y1
I just wanted to know if it could be identified. Now I can go in search of a piston!
Thanks for the responses, Jerry
« Reply #5 on: June 24, 2017, 11:43:59 AM »
Do you believe that any old piston will fit?  These things are usually matched, and then honed or lapped.
« Reply #6 on: June 24, 2017, 03:18:33 PM »
if it is a Magnum 36   I will buy the  head from you,  the sleeve  is a  piston/sleeve matched pair, so the sleeve may, or may  not  work  for you
« Reply #7 on: June 24, 2017, 05:20:51 PM »
Randy,
You have my attention. Do you want me to send it to you?
Floyd, Yes, I know they are in matched sets. And NO, I'm not looking for any old piston!  LL~ LL~ LL~ Unless of course you have one laying around that will work.......  o2oP
« Reply #8 on: June 24, 2017, 08:51:12 PM »
Randy,
Yes  let me know what you want for it, send it to me  if it is a  Magnum 36 head  I will buy it, if not I will send it back
« Reply #9 on: June 25, 2017, 09:11:55 AM »
Ok, will do.
Jerry
« Reply #10 on: July 06, 2017, 01:54:19 PM »
Randy,
Did you get the head? And is it what you were looking for? Or are you going to send it back?
If its what you are looking for, is my price/deal OK with you?
Thank you, Jerry
PS: Yeah I know, lots of questions! LOL.
« Reply #11 on: July 06, 2017, 02:26:06 PM »
Randy,
Thank you, Jerry
Hi Jerry
yes  i have it, the head is  a Mag 36 and I can use it, the sleeve  is useless to me, but  yes  the parts you asked for I am getting up, I have the venturie  , and I have every Enya  NVA  but that  one, however if you want a  ST tye  I can send that now, or I have 45  size  NVAs  coming
Randy   678 407 9376
« Reply #12 on: July 06, 2017, 07:12:49 PM »
Hi Randy,
Thank you. I would rather have the Enya type. I don't want to drill the venturi to fit.
Looking forward to a fine running engine!
Cheers Jerry
« Reply #13 on: July 22, 2017, 01:38:35 PM »
Thank you Randy!
I got home last night after a hard week of fishing and there it was. It is perfect!  ;D
Jerry
