  • June 17, 2025, 12:31:39 PM
Author Topic: Testors McCoy 35  (Read 1455 times)
Offline Paul Allen
Testors McCoy 35
« on: July 15, 2013, 04:12:01 PM »
Is this motor any good for stunt, Testors McCoy 35, Series 21.
Paul in OZ
Re: Testors McCoy 35
« Reply #1 on: July 15, 2013, 05:05:11 PM »
Hi Paul,
The Series 21 .35 is identical to the Red Head .35 except for the Dykes ring in the Series 21 and its extra weight.  It is a typical 1960's 4-2 style .35.  Not a real "powerhouse"............
BIG Bear
RNMM/AMM
« Reply #2 on: July 15, 2013, 06:02:42 PM »
Hi Paul,
   If you get a good one, it's a remarkably steady runner with an excellent predictable 4-2 break if desired. The problem is finding a good one. The quality control was the absolute pits and makes Fox look like a precision outfit. Finding one that runs right is a complete crap-shoot, fortunately, they are (justifiably) very cheap.
« Reply #3 on: July 22, 2013, 06:02:24 PM »
Paul, if you can find one the 40 would likely be better.  It seems whenever a mfg. build several sizes of motor on the same case the largest one makes a better stunt engine
As far as the fits go, you may end up having to try several rings or get from one of the suppliers(frank Bowman, etc.)
