Engine basics => Engine set up tips => Topic started by: Robert Zambelli on January 25, 2011, 07:39:29 PM
Title: SEALANT
Post by: Robert Zambelli on January 25, 2011, 07:39:29 PM
I decided to post this after reading the thread about the OS 25.
Mention was made of the anaerobic gasket compound. Check out the photo.
I have been using this compound for the last fifteen years and I have NEVER had a leakage problem.
I've used it on Diesel, glow (up to 30% nitro) and spark (gasoline) engines  and it does have it's place. It can function at 100% strength up to 125 C.
From what I've read, it is not for high temperature applications - use hi-temp silicone for that.
DO NOT use silicone to seal against gasoline - it will break down.
My standard procedure on all of my engines is to remove all paper gaskets and apply the anaerobic compound, allowing as much metal-to-metal contact as possible.
Just my results - yours may vary.
Title: Re: SEALANT
Post by: Bill Little on February 05, 2011, 08:20:06 PM
HI Bob,
I can't see who makes it.  Only the part number. ???
Title: Re: SEALANT
Post by: kenneth cook on February 06, 2011, 02:50:54 PM
         Bill, Permatex is the manufacturer its found in most of your local auto parts chain stores. There is quite a bit in that small tube. Ken
Title: Re: SEALANT
Post by: tryhard on February 08, 2011, 06:36:36 AM
The manufacturer of 518 sealant is Loctite. See here for datasheet http://docs-europe.electrocomponents.com/webdocs/002c/0900766b8002c4c6.pdf
