  • August 02, 2025, 06:57:44 AM
Author Topic: Fox engine question  (Read 3100 times)
Offline Gary Dowler
Fox engine question
« on: September 30, 2018, 05:40:00 PM »
Preping and old Ringmaster that I was given. Mounted a Fox 25 that I had, as my other OS 20FP is spoken for on my Flight Streak.
I have the muffler, a stock Fox muffler with mount homes both top/bottom and side/side. This needs the top/bottom holes. It's not for a 4-40 bolt, that seems certain. A 2-56 seems the right dia (a 5/64 drill bit shank (.077") will just slide into the hole) A 2-56 bolt is .085" dia and seems like it wants to start, but only goes in freely about 1/8".
What size is this supposed to be? I can redrill and tap for 4-40 easily enough, but I prefer not to.
Gary
Offline Bob Matiska
Re: Fox engine question
« Reply #1 on: September 30, 2018, 06:10:28 PM »
I'm 99% certain the mounting screws are 3-48, that size between 2-72 and 4-40. I've dealt with Fox mufflers on my engines, too.
Bob in NEPA
AMA 56267
« Reply #2 on: September 30, 2018, 06:24:35 PM »
      Probably 3-48. But, try to find a way to strap-mount the muffler. The over/under muffler connection was notorious for racking the crankcase out of "true", and also, for pulling a chunk out of the crankcase in a crash.
   The short "ears" were slightly better, at least when they broke, it just broke the ear off. The only way that really worked was with the 50th anniversary "full length" lugs that looked like a crude version of the ST46 mounting lugs. You can sort of create the same thing on an "ear" crankcase by JB-welding some tubes to form the ST46-style mount, but that is not 100%. Straps for the "non-ear" version and the "no provision at all" versions (which are most of them...).
Offline Gary Dowler
« Reply #3 on: October 03, 2018, 01:57:41 AM »
Yes, they are 3-48 for these muffler bolts.   Locally there were no 3-48'st to be had that weren't for a flat screwdriver, which would be impossible to utilize because of the angle involved.
They were then drilled out and retapped for 4-40 thread, and hex headed 3/8" long bolts attached it just fine. A more secure strap might be a better solution down the road, but for now this will work.
Gary
Offline Mike Anderson
« Reply #4 on: October 03, 2018, 09:26:05 AM »
Be very sure that those muffler bolts are not too long - if they contact the sleeve, they will push it out of round -- I speak from experience.
Mike@   AMA 10086
Central Iowa
Offline dennis lipsett
« Reply #5 on: October 03, 2018, 10:30:50 AM »
Socket head 3-48 bolts can be bought from either RTL  or Micro Fasteners. i redid a bunch of Fox 25 4 bolt Backplate models from the 70s and put new gaskets on them and them sold them on this forum
Offline Gary Dowler
« Reply #6 on: October 03, 2018, 11:32:20 AM »
I measured pretty carefully and would drill/thread in stages until I got the muffler to seat, then stopped. I can detect no difference in how the motor turns by hand.  I think it's ok, but running it will be the test.
Gary
« Reply #7 on: October 03, 2018, 04:03:20 PM »
I went to both sites as I too need some 3-48 bolts.  None listed either site. HB~>
I decided to do a search on the internet for 3-48 screws/bolts.   Nothing I found would serve our purpose. HB~>
« Reply #8 on: October 03, 2018, 07:04:43 PM »
McMaster-Carr at https://www.mcmaster.com/standard-socket-head-screws, 3-48 in carbon steel, and two different types of stain steel, lengths from 1/4 inch to 1 1/4 inch.
« Reply #9 on: October 03, 2018, 08:55:16 PM »
John,
I went to the micro fastener site and found 3-48 socket screws from 3/16 to 3/4 inch. RTL would also have them. Fox engines are not so special that  they need some unobtanium size bolt
Dennis
Online dave siegler
  • sport flier
    • Circlemasters Flying club
« Reply #10 on: October 04, 2018, 10:41:24 AM »
Locally my good hardware store, Ace hardware has #3 hardware in the specialty bolt section.  Need to look around they are there.
Also try your local gunsmith.
ACE also had the hard to find 5-40 screws for cox prop screws.
Dave Siegler
NE9N extra class
AMA 720731
Offline Gary Dowler
« Reply #11 on: October 04, 2018, 07:49:16 PM »
Thanks for all the info guys!  I would have preferred to have just used the correct hardware, but time was too short to order stuff. But now I have more info that I had yesterday!!
Gary
