  • June 15, 2025, 12:11:57 AM
Author Topic: Venturi size for .40 Diesel?  (Read 1158 times)
Offline frank mccune
« on: May 25, 2023, 06:57:44 AM »
      Hello all:
       I am planning to convert an Irvine .40 RC Diesel to cl use.  What size of a hole in the venturi would work? Could I just wire the RC carb open for cl use?
       Tia,
       Frank
Offline Peter in Fairfax, VA
Re: Venturi size for .40 Diesel?
« Reply #1 on: May 25, 2023, 09:01:29 AM »
Frank,
What's the venturi ID on the r/c carb?  That might suggest a starting point.
Yes, holding open the r/c carb has been done.  Some carbs even ease this by allowing the idle stop to hold it open (early O.S.)
Peter
« Reply #2 on: May 25, 2023, 03:11:12 PM »
  A C/L venturi with a spray bar through it is way different than an open R/C carb with nothing to restrict it. If going with the R/C carb, set it with the throttle closed to about 2/3 throttle for initial running and see how you like it. Just set the needle for the RPM you want just like normal.
« Reply #3 on: May 25, 2023, 03:45:48 PM »
Dan's got a point here.  An open "true venturi" ID is different than a venturi restricted by a spray bar.  As I understand it, if you calculate the "free area" carefully, the two are roughly equivalent.
« Reply #4 on: May 25, 2023, 03:57:29 PM »
       Thanks for the prompt replies.
        Frank
