  • June 16, 2025, 04:39:27 AM
Author Topic: Say "Ahh"  (Read 1224 times)
Say "Ahh"
« on: December 25, 2010, 08:56:25 PM »
Will an OS FP-20 work well on a tongue muffler?  I've got a Sig Skyray that could use the CG shifted further back, and would like to do the job by adding lightness to the front, instead of weight to the back.
On a related note, does anyone know where I can get a life-size casting of a tongue, in a reasonably easy to machine aluminum alloy?
Re: Say "Ahh"
« Reply #1 on: December 25, 2010, 09:06:52 PM »
It will "run" on a tongue muffler just fine.  But to get the optimum "Stunt Run" it really has to have the stock 2030 muffler and a 9-4 APC prop.  This is really about the closest thing you can get to a piped motor run with out a piped motor!  Commonly referred to as the BBTU.  I would balance the plane by other means and leave the 2030 in place.  It really will make that much difference.
(In case you didn't know: BBTU= Brett Buck Tune Up)
Re: Say "Ahh"
« Reply #2 on: December 25, 2010, 09:56:28 PM »
Well, I guess that saves me from an hour spent cleaning casting sand off my tongue.
Re: Say "Ahh"
« Reply #3 on: December 25, 2010, 10:19:50 PM »
Tim,
For whatever reason, the OS .20FP BBTU is an out of the box "pipe motor" run.  Not all of the engines out there (even other FPs like the .25FP) act exactly the same way as the BBTU does.  The BBTU comes as close to a pipe run as possible with out being one.  You'll hear a LOT of people talking about great engine runs, but until you experience it, you won't understand what all the talk is about.  Short of a high zoot competition engine (read mega bucks), the vast majority of the rest of the engine "runs" I see are mostly just "good" engine runs.  The Magnum .36XLSIIA square head, set up like PTG developed, will do the right stunt dance, also, for about $70-$80. ;D  (I guess Hobby Lobby still sells those! LOL!! )
Offline kenneth cook
Re: Say "Ahh"
« Reply #4 on: December 26, 2010, 06:01:01 PM »
       Bill, this setup as you referred to as the BBTU was tried recently at our club. For whatever reasons, we tried everything to the letter and not so good results. I'm not here to say that it doesn't work or to argue an already proven fact. I was wondering if it was the result of us using the steel version engine. I found that mine worked much better using the tongue. I was using a Randy Smith tongue no extra holes and the holes were enlarged to 7/64th. I found the engine to be retaining to much heat. I use Powermaster fuels 10%nitro 22% oil. I found the engine to purr right along when the tongue was added. What I did find out though is that my stock muffler ISN'T the one you've mentioned above. In comparison, mine is slightly fatter and a touch shorter but other than that, they are very similar. My muffler still has all its internals intact as well with the exit being the stock size. As for my partners, everything he had was by the instructions per Brett. He even launched at the required rpm which I can't recall off the top of my head, but the plane would eventually sag. I somewhat questioned his motor as he purchased it used and really didn't know its history. Mine though was purchased by me and seldom run other that breaking it in. I'm flying a somewhat heavier kit built Flite Streak while my partner was flying a Skyray.35. I would say I had much better results using the tongue. Are most users of this engine prone to using the ABN version?Ken
Re: Say "Ahh"
« Reply #5 on: December 26, 2010, 07:09:04 PM »
  All of my experiments were with box-stock ABC versions using the supplied E2030 muffler.  It wouldn't overly surprise me to find you might need to do something a little different with a iron-piston engine, but I would think that at most you might need to use different fuel.
   What is it doing wrong?
Re: Say "Ahh"
« Reply #6 on: January 01, 2011, 05:40:33 PM »
hi Kenneth,
Don't know what to say.  it is opposite of any experiences I have had withe OS .2OFP BBTU.
I am no engine expert.  No great pilot either so my opinion is significantly less than most's.
I have 4 or 5 of these engines and have run all but one.  The one I haven't run is one set up by Dan Rutherford and I "won" it in a long ago contest at SSW.
The first one I used was a steel piston one that I later converted to ABN. (it was well worn when first put into use so a new S/P was thought needed).  The power was restored, but the "run" wasn't significantly different afterward..  All usage has been (so far) on what Da Dirt calls "Pukey Profiles".  All have good noses, and the fuel systems have caused no problems.  Have always used Sig 5% (or 10% when it's real hot around here)  1/2 and 1/2 "Champion", it's what I can get the easiest around here.  Never had a surprise and once the needle is set on a new plane, nothing else much is done, and no surprises have been encountered.
I am sorry that y'all had problems, I can't say what the fix would be. ???
I can say that the system as Brett suggests only works in the manner described using the stock parts specified.
A couple of "guesses", if it sagged, the needle was probably too lean, regardless of "RPM", or some other fuel system gremlin could have been the culprit.  A weak engine to start with is "calling off all bets."  Don't know the fuel you used either, but as long as it was fresh, I guess it should work, ok.  The run is a constant 2 cycle.  The engine pulls a bit more going up and shuts off a bit going down.  Not a tremendous difference in the "sound".  Never used anything but a balanced 9-4 APC.
Next "installment" will be a "Super Combat Streak". liked that model since my first one in 1971.  Fun to fly and practice with!  Will probably use it for a Classic contest, too, if I fly in another contest! LOL!!
Sorry!
