  • July 12, 2025, 06:50:32 PM
Author Topic: Save those glowheads!  (Read 1782 times)
Online Larry Renger
« on: September 13, 2012, 09:53:06 AM »
I have had a problem with the elements in my gloheads getting a white coating and the needle becoming unreliable as a result.  At the AMA Expo, I talked to Mr. Kelley, the owner of Merlin plugs.  He recommended two things:
1.  Reduce the compression a bit to eliminate or at least slow the buildup.
2.  Recover the plugs by soaking the element in Muriatic Acid from a swimming pool.  Neutralize the acid with a solution of baking soda.  Finally, oil the plug cavity to re-seal the gasket.
Dang!  It works!!!   #^
Online Brian Hampton
Re: Save those glowheads!
« Reply #1 on: September 13, 2012, 11:06:56 AM »
Muriatic acid is hydrochloric acid, although I suspect very much diluted. However I've also heard that plug coils can be cleaned using vinegar which is diluted acetic acid. Vinegar is also extremely good at getting rid of rust although it takes a couple of days.
Offline Mike Greb
« Reply #2 on: September 13, 2012, 05:29:29 PM »
Muriatic acid can be used to strip  chrome off a abc liner.
Offline ash
« Reply #3 on: September 13, 2012, 05:57:12 PM »
I've used it to dissolve aluminium mandrels. I'd be hesitant to put it anywhere an aluminium glow head, but it seems to work for you!
« Reply #4 on: September 14, 2012, 10:07:22 AM »
     Note that this is only supposed goes in the "well" that contains the element. Don't submerge  the whole thing in muriatic acid!
    I heard this a couple of years ago, and tried it on a rather "frosted" Thunderbolt 4-Cycle plug. The be honest, I couldn't tell the difference, but I may have had a different problem to begin with.
Online Larry Renger
« Reply #5 on: September 14, 2012, 04:43:31 PM »
Agreed, Brett.  I have a small bottle with a CA dispenser tip so that I just cover the element with the acid.
Sorry, I should have mentioned that!
« Reply #6 on: September 15, 2012, 12:46:24 AM »
They really put muratic acid in swimming pools? I thought they just dumped chlorine in 'em. Muratic acid might be used to clean a swimming pool (it is sold here to clean driveways & patios), but then we'ns don't know chit about swimming pools.  H^^ Steve
Offline Rafael Gonzalez
« Reply #7 on: September 15, 2012, 06:34:48 AM »
The acid is used to stabilize the PH.
 H^^
Offline Heman Lee
  • AeroManiacs
    • AeroManiacs
« Reply #8 on: September 17, 2012, 07:24:33 PM »
Same thing as drive way.  Use to clean the pool before painting.  I had to re-paint a rental pool a few time.
Offline James Strickland
« Reply #9 on: October 14, 2012, 08:17:13 PM »
Ash is absolutely correct, if you get muriatic acid on aluminum,  the aluminum absolutely goes away,----way far, to never come back again....
