  • June 21, 2025, 10:14:03 PM
Author Topic: Break in for Magnum 36  (Read 952 times)
Online James Mills
« on: May 11, 2007, 09:23:15 PM »
What's the best approach for breaking a Magnum 36?  Do I need to kick it up into 2 stroke during the run or just let it run at a fast 4 cycle?
James
AMA 491167
Re: Break in for Magnum 36
« Reply #1 on: May 12, 2007, 05:43:55 AM »
james, Randy said (if I remember correctly) to run it in a wet 2 and then pinch the line every so often.  No 4 cycle, at least not a slobbering rich one......... ours did not take much breaking in at all. ABC construction and a good fit, so just some running to get familiar with it!  Ours did get a little better on gas milage after several flights, but the run characteristics didn't change.
Bill <><
Offline Ward Van Duzer
« Reply #2 on: May 13, 2007, 02:04:44 PM »
Read Randy's article in the front of this forum. FUEL, GLO PLUGS, AND RUNNING TIPS.
The whole article!
Ward-O  H^^
