  • June 20, 2025, 03:16:45 AM
Author Topic: ST .56  (Read 1439 times)
Offline Ty Marcucci
ST .56
« on: June 06, 2006, 09:32:38 AM »
I had two ST .56 engines. Got rid of them...
« Last Edit: April 11, 2020, 08:30:03 PM by Ty Marcucci »
Ty Marcucci
Re: ST .56
« Reply #1 on: June 06, 2006, 10:53:03 AM »
The  ST 56  runs  a  lot  like the ST 60 and  ST  46, many have  used it,
I saw a  Magnum in one  that ran  very well
Re: ST .56
« Reply #2 on: June 08, 2006, 04:55:24 PM »
I was using several ST/56's a lot 12 years ago. Randy is correct that they run pretty much like the ST/60. Some versions have a small amount of sub port induction at the left side of the exhaust. On other 56's the sleeve covers this spot. Trying to run a stub muffler on the ones with the sub induction will give a eratic run.Use a tube muffler and the problem will go away.Also some 56.s have a litter faster timing but they sure work well in a SV-11.
