  • June 24, 2025, 09:52:02 AM
Author Topic: S.T. G-21 Venturi ?  (Read 937 times)
Offline YakNine
S.T. G-21 Venturi ?
« on: June 02, 2010, 07:14:46 AM »
Hi Guys, I have been taking all my stuff out of storage after 25 plus years. I was oiling up my G-21 .40 the other day and noticed that there is no spigot tube in the venturi just a hole in the aluminum. I am assuming that it is missing but did some of them come this way? If it is missing are new ones available? I have never run this engine since I owned it but I remember my dad's buddy who gave it to me running it and it seemed ok but then again that was probably 30 years ago!Thanks T.J.
AMA 85135        GSCB
Re: S.T. G-21 Venturi ?
« Reply #1 on: June 02, 2010, 08:57:45 AM »
     It came that way. There are six holes spaced around the narrow section.
« Reply #2 on: June 02, 2010, 09:53:46 AM »
Unless it's the big one, which has one big hole for the spraybar to pass through on the aft side.
Offline YakNine
« Reply #3 on: June 03, 2010, 09:18:14 PM »
Well Brett you were right I got out my flashlight and my reading glasses and saw the other holes my eyes were a lot better when this engine was put away 25 years ago. Thanks T.J.
AMA 85135        GSCB
« Reply #4 on: June 14, 2010, 01:22:07 AM »
Try it on the big one .
« Reply #5 on: June 14, 2010, 09:00:13 AM »
Make sure you clean the holes out, they are very small and may times I have seen stored engines with some holes blocked
