CLICK HERE--><--CLICK HERE
Running advice for Aero Tiger 36.
Started by Robert Zambelli, September 20, 2026, 05:59:49 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Robert Zambelli
I was flying my new Magician Friday with some strange results.
10/6 Soar wooden prop.
5% nitro/20% 50-50 castor/synthetic.
Four ounce metal tank, muffler (tongue) pressure.
Super easy starting, took of with a nice fast four cycle - perfect speed for the plane.
After around five laps, it instantly went to screaming lean, and continued for the rest of the flight.
Did not change no matter what maneuvers I tried.
Actually sounded like a combat run.
I confess to having very little experience with this powerplant so any help would be appreciated.
Any suggestions ???????
kenneth cook
             The examples I've seen were using pitch props less than 6. The users said to treat this engine prop wise similar to the FP.40 using the APC 10.5x4.5 and or the 11x4.5. It was also mentioned to me that they were using more synthetic percentage in their fuel with totals up to 16% and 6% castor.
Motorman
Tongue muffler can be less restrictive and so provide less pressure. Where does the pressure line go inside the tank? top/inside/front I hope. If the pressure line is hooked up to a uniflow tube you're just blowing foam back to the pick up tube when the revs come up after launch.
MM :)
Reptoid
Std Magician?
   In delivered form the Aero Tiger will likely be excessive power for that size airplane. For starters I would go to a 4" pitch prop 10.5" to 11" diameter. For that size airplane you might want to go to a smaller venturi as well
       Don
       AMA # 3882
Robert Zambelli
Thanks for the good advice.
All suggested mods are easy to accomplish.
I will first try a smaller pitch prop.
I have many 10 to 11 inches in diameter, 4 and 5 pitch.
Motorman - yes, that's exactly where the pressure line goes (top/inside/front).
No uniflow of course.
I was also wondering if the muffler might be too restrictive, causing the engine to overheat and go lean (?).
Again, suggestions welcome.
Steve Helmick
#5
A couple of questions. Is this a Randy reworked TT .36 with the OEM ABC piston/cylinder and reworked, or the full meal deal Aero Tiger .36 with the AAC piston/cyl. that Henry Nelson made for Randy? Was the tongue muffler the one that Randy sold with the engine? He liked a tongue muffler for them. He also didn't like muffler pressure. I'd absolutely recommend trying the Yoshioka 11-4.5 (aka Thunder Tiger Cyclone) that Brodak shows in their catalog. That is a killer propeller for anything in the .36 > .46 range of modern-ish engines. You know...the ones that are no longer manufactured. OS, Magnum, ASP, Thunder Tiger, etc.
Bye the way, you indicated that your fuel tank is not a uniflow. Why? I'm a fan, also a fan of hooking the pressure hose to the uniflow inlet. Stops the upwind rich, downwind lean nonsense, keeps tiny bugs and seeds out of your fuel tank/filter, and makes life easier in general. However, if folks have trouble with things coming loose (i.e., mufflers), they should absolutely avoid muffler pressure. Steve
Brian Hampton
I had a very similar problem years ago with an ST G51 (Italian with stunt timing) which would go screaming lean as soon as the nose pointed up then took 2 level laps to go back to a 4 stroke. For about a month I tried everything I could think of to cure it but no luck and I was ready to throw it back into its box and give up. On what was to be its last flight forever I ran out of my usual 80/20 all castor fuel but I had another tin of 75/25 all castor so I figured what the heck,I've got nothing to lose. Wow! That totally transformed the ST into a brilliant 4-2-4 run. It took me a while to figure out what caused such a change but eventually it dawned on me that I'd always known it was very economical on sipping fuel but that also meant it was economical on oil supply too.So low oil flow meant overheating!
Like Like x 1 Funny Funny x 1 View List
Steve Helmick
My ST G.51 did just fine on 10% nitro, 11% castor, 11% Klotz. Two different cylinder timings, one an R/C cylinder retimed to GMA specs, and the other a stock factory CL cylinder. Different props, same fuel, both worked very nicely. The GMA timed cylinder liked a 12-5 APC or 12.5 x 5 Thunder Tiger Cyclone. The CL spec cylinder likes the 12.25 x 3.75 APC. If I was running a G.51 with a BG ABC conversion, I'd use 10% nitro, 18% synthetic and possibly add an ounce or two/gallon of Randy Smith's mystery sauce. I don't know what's in it...it's a mystery. I'd run the same stuff in an Aero Tiger .36 after some bench running on 10/22.  Steve
Alan Buck
Bob  aero/tigres do not like on profile plane  same goes with PAs
ALAN E BUCK
Steve Helmick
Quote from: Alan Buck on October 04, 2026, 07:19:37 AMBob  aero/tigres do not like on profile plane  same goes with PAs
Young Jimmy Rhoades had an Aero Tiger .36 (side mounted) on a profile Imitation...modified to a typical profile slab nose. Worked very well, and won Expert Profile at Fall Fallies about a decade ago. CF 3 blade, IIRC.
Gordon Tarbell
I have Bob Duncan built modified Imitation with side mounted Randy smith Aero Tire 36 with a CF 10.75 X 3.8 that ran and flew great until pushrod end at elevator horn failed. Awesome combo , hope to repair and fly again now that I am retired to FL.
Gordon Tarbell AMA 15019
Brett Buck
Quote from: Gordon Tarbell on October 29, 2026, 07:09:33 PMI have Bob Duncan built modified Imitation with side mounted Randy smith Aero Tire 36 with a CF 10.75 X 3.8 that ran and flew great until pushrod end at elevator horn failed. Awesome combo , hope to repair and fly again now that I am retired to FL.
    I think the Aero-Tiger is one of the best 4-2 break engines ever made, a big upgrade in performance for the smaller ST-46 airplanes and it makes sort of a mockery of Classic. Runs fast enough to spin modern props instead of ancient 50's-style 6" of pitch. On a muffler I would take it over a PA40 any day.
Robert Zambelli
Gents: Thanks for all the interesting replies.
Unfortunately, I have been away and not being able to test out some on the suggestions.
As soon as I'm able, I will get back to my testing and report.
Dave Moritz
Robert
Please check for a PM from me.
Dave Mo...
" In a world of ready-made fiction, truth requires work."
D. Andersson
