  • July 08, 2025, 02:50:30 PM
Author Topic: R&R cylinders from engines????  (Read 3451 times)
Offline frank mccune
« on: November 19, 2018, 10:10:21 AM »
        Hello All:
        How does one remove a cylinder from an engine? How does one replace the cylinder in the case?
         I am experiencing a bit of a sticky wicket with a HP .40 engine.  The cylinder was TIGHT in the case where getting it out nearly involved Divine Intervention! To install the cylinder is appearing to need the same miracle.
         I got the cylinder out but to get it back in, what do I do? Do I reduce the O.D. of the sleeve or increase the I.D. of the case?  I am looking for a light sliding fit, light press fit but not a shrink fit. How do I acheive this "perfect" fit?
         I won't go into details of how I got the cylinder out of the case as it may cause major trauma to engine peope that would result in very  lengthy and expensive theraphy. Lol.
        Tia,
        Frank McCune
Offline bob whitney
Re: R&R cylinders from engines????
« Reply #1 on: November 19, 2018, 11:48:56 AM »
a wise man told me  A little sandpaper go's a long way.  to get it out  to get it out leave the prop on ,find some gloves a propane torch and a Popsicle stick. remove the head.    heat the cylinder part of the case until Spit Will bubble on it put the Popsicle stick down the sleeve and wedge it s little bit into the exhost port turn engine over by the prop until piston touches the stick.push the stick with the piston. should push the sleeve up enough to get a hold of it and remove it
 look to see if there is any grunge on the sleeve or in the case. take some 400 W/D sand paper and clean the outside of the sleeve and the inside of the case clean with soap and water then do the same thing again with 600and clean..see if it will slide in
if u have a lathe or drill press y can make a wooden mandrel that wont hurt the sleeve and spin it while using the sand paper
rad racer
« Reply #2 on: November 19, 2018, 01:25:26 PM »
Oh, the horror...!
« Reply #3 on: November 19, 2018, 01:38:07 PM »
There is  no  one  way to do what you are asking,  a  steel sleeve is a very different fit than a  brass   or  aluminum sleeve is.
The  HP 40 has  both  steel and  brass, the  brass sleeve can be  a slip in fit, but the  steel sleeve  needs  to be  a press fit
You also have the problem of the  ABC-Ring  that is in some  HPs    what model do you have ?
« Reply #4 on: November 19, 2018, 01:39:17 PM »
and  NEVER  EVER  EVER   take a flat head screw driver  to the lip of the sleeve,  or  a  pair of pliers
« Reply #5 on: November 19, 2018, 02:05:40 PM »
Frank,
Reason this thru. If the cylinder is made for that engine, and the parts have not been buggered up, there should be no reason any metal removal is required. Unless we are talking prehistoric engines or really crummy makes that are made with hammers and hacksaws. I've never seen an OS, Enya (limited experience here), Super Tigre, OPS, Pico, etc. that needed metal removal to reassemble--if the parts were not damaged during disassembly! I have not had the opportunity to work on an HP, but am having trouble believing they have poor tolerance control or are designed with an excessively tight shrink fit. If they do, then the following comments are even more important.
Many engines allow slight shrink fits based on their tolerancing. I suspect that there are speed guys out there that will tell you that the sleeve needs clearance to avoid distortion from the case. I wouldn't do that and I suspect that issue is better solved by a cowling that controls the heat more evenly. Most of the engines I can think of have liners too thin to be unsupported. Again, that is an opinion. If I see a speed guy consistently doing better than 80% of the record time without the engine coming apart, then I will certainly acknowledge his fit-up skills. But that ain't most of us!
Most disassembly issues come from the engine being gunked up with burned on oil, and trying to pull the liner without getting it cleaned up first. And then the unwillingness to heat soak in an oven to achieve the required differential expansion. Most clean engines come apart at 200F or so. I have had some that needed as much as 300F. This is compounded when the wrong tools or techniques are used. You need to make up a sleeve puller if the sleeve won't simply drop out after proper heat soaking.
I recently disassembled an engine that appeared to have swallowed a ring and then was "rebuilt" but without fixing the underlying damage. Anyway, it had damage to the edge of one of the ports. It was therefore more difficult to remove, even with a puller. It came out but I had to dress the deformed edge of the sleeve port and clean up the scoring on the liner. I have not test run that engine yet, but my expectations for the liner and piston are not very high.
I would also note that if this is a lapped fit engine, if you change the sleeve shrink fit to the case that you are also c hanging the piston/sleeve running fit. This also occurs with the bearings, which are generally shrink fit to the case. Better to learn how to work on the engine the way it was designed to work, than to come up with a way to alter parts so it is easy to put together but now runs like it is worn out.
All of this assumes that you are talking about an engine with a steel liner, and not an AAC, which should be true of all of the HPs as far as I know. Then again, if you are putting custom aftermarket parts into your engines, you may be encountering/creating all kinds of new issues.
Best of luck,
PS--From prior conversations here, I would say that what you called your "tuition" is going to get expensive real soon....
PPS--"Devine Intervention" on your disassembly work sounds suspiciously like a euphemism for "damage" to me.....  Hope not
« Reply #6 on: November 19, 2018, 02:09:24 PM »
Seen a few with pliers marks on the sleeve flange, Randy?
Ghastly, ghastly......dastardly work. And then someone expects you to fix it?
« Reply #7 on: November 19, 2018, 04:19:36 PM »
       Hi all:
       Thanks for the prompt replies.
       I got the cylinder out after a bit of hassle.  I could describe how I did it but I fear condemnation from a few of the less adventuresome readers. Teaser, it included the use of Channel Lock pliers Lol  I did no damage to any thing but I see that the cylinder will not begin to enter the crankcase at room temperature.  I have been warned NOT to use a heat shrink fit on this engine as I will never get the cylinder out of the block again.  This idea is what prompted me to think of removing metal from the outside of the cylinder to permit a "snug" slip fit. I have been told to make up a mandrel and use a bit of abrasive cloth to open the crankcase to permit the cylinder to enter the crankcase.  I have also considered removing a bit of metal from the outside of the cylinder with abrasive cloth to aid in assembling the cylinder to the crankcase.  Any suggestions of what to do to get these parts assembled?
     In the meantime, I will await your comments and suggestions.  I will also "clean" the cylinder and crankcase to be certain that all dried oil has been removed.  I do not think that this engine has been run but there was what looked like dried, "petrified" oil between the cylinder and crankcase!!!!   The other HP .40 Silver Star that I pulled the cylinder out to replace it with a Brian Gardner P&C allowed me to just use the popsicle stick in the exhaust port and pull the cylinder out by finger strength.  The BG piston and cylinder dropped in with ease.
      Again thanks for taking the time to reply to my dilemma!
        Be well,
        Frank McCune
« Reply #8 on: November 19, 2018, 04:44:27 PM »
        Hello All:
        Just a few observations re. the HP.40 with which I am struggling with, The Silver Star ,circa 1970, engine in question has a steel cylinder, an aluminum piston with a conventual cast iron ring.  I hope that this information helps in understanding my problem (s)
        Tia,
        Frank McCune
« Reply #9 on: November 19, 2018, 05:31:12 PM »
been reduced to a bigger tube say a inch long over the top , a washer or plate there .
A washer , something like a heavyish prop washer , the taper helps centralise , . . . but . . . may expand it .  >:(
slightly less than the sleeve / case hole / bore diameter .
Bolt thru from top , not in C shaft area . Might need a spacer or two up top , as you go .AS IN making a puller , And AVOIDING distorting parts .
Found the paint stripper heat gun beats hot water any day .
Often once its started , C R C will wick in better .
Often its dried castor reidue GLUED it together - So needs disolving , but the solvent cant get in .  >:(
« Reply #10 on: November 20, 2018, 11:20:21 AM »
       Hi all:
        You surely aren't trying to re-use the channel-lock-modified liner, are you?   Fortunately:
https://www.mecoa.biz/shopdisplayproducts.asp?id=121
Part #12-2101 CYLINDER, HP .40 SS $27, good stock status
       In any case, I would assume the only way to install the replacement is to heat up the case to expand it, then *rapidly* install it.
   There may be a burr or slight distortion somewhere in the case but I cannot imagine a safe way to remove significant material from the outside of the liner in any quantity. Removing any significant material from the case without a boring bar in a lathe can easily result in distorting the case, which will transfer some of the distortion to the liner when you install it.
     If it's an iron liner in an aluminum case, it is supposed to be a very tight fit cold, so it will transfer heat when the engine is running. The case will expand much faster than the liner with temperature, and you want them to still be in contact, so it will need to be very tight fit cold.
     A brass or aluminum liner has a different fit, it can be a push-fit at room temperature.
« Reply #11 on: November 20, 2018, 11:56:53 AM »
Yes  unfortunately  I have seen many dozens with plier marks, others with screw driver marks, both on the lip and in the exhaust ports.and have seen AAC engines locked up with the cylinder welded in place from trying to remove the sleeve with hard carbon build up on the  outside of the sleeve at the exhaust, this debris got into the fit between the sleeve/case, and  forced zero tolerance between the two aluminum parts, then the weld together and bot are ruined. Many 1000s of dollars  I have seen lost by people killing parts by doing things that hurt the motor they are trying to help.
Other things are people sanding , honing, grinding fits too large or too open, I see this mostly on Super Tiger and  HP  engines.
Some factories make mistakes with this too, example  I have seen many Magnum engines  with hard press fits in some of their engines, You can assemble them this way, but it makes it very very hard  to take them back apart
« Reply #12 on: November 20, 2018, 12:07:44 PM »
       Hi all:
        Be well,
        Frank McCune
Hi Frank
I can tell you with about a  99.999 percent certainty that yes you did harm the sleeve, the top of the sleeve will be bent/warped one way, so plan on a new sleeve.
Whoever told you not to use the press fit, is wrong, you will need the press fit with a  steel sleeve, make sure the inside case is clean and smooth with no burrs, and also the outside of the sleeve, on a  HP you put the piston sleeve ring pin and all in the case at the same time, Heat the case and drop in the whole assembly, take care to make sure the ring gap is in the correct place, and  take care  to slide the assembly in straight where the exhaust port is lined up correctly,
There is no problem taking them apart, quickly heat the outside of the case, and  push the sleeve out from the bottom upwards by putting a 1/4 in dowel in thru the backplate opening, then grab the top of the sleeve with a  rag
« Reply #13 on: November 20, 2018, 03:22:38 PM »
    Hi Randy et. al:
    When I used the Channel Locks, I placed NO "squeeze" on the cylinder! I used them a fixture to hold the cylinder without any force on the cylinder.  When the case was heated, I tapped the case away from the cylinder with a very light tap on a wooden dowel inserted in the bore of the cylinder and resting on the bottom of the case.  No damage or marking on the lip of the cylinder was done.
    Oh yes, there was no way that a wooden dowel would refrain from splitting when I attempted to tap the cylinder out of the case.  I could only move cylinder to a point to where the cylinder skirt was even with the channel in the case.  I then used a bit of heat and a dowel to tap the case away from the cylinder.  I tried a heat gun, oven at 300F and a propane torch.  Don't fret, the propane torch only reaches about 2100 F but has to be used very wisely!!!!  I used smoke from ATF as a temperature guide to give me a rough indication as to how much heat was in the case.  I did not have any temperature indicating crayons so I had to resort to culinary experience.  It must have been done correctly as all the parts fit back together perfectly.  Sometimes one gets lucky. Lol
    Now, for the assembly.  How tight should the cylinder fit into the case?  Is it  light interference fit? If so, how do I accomplish this?  Randy. you warned me NOT shrink fit these engines together as I would never get them apart again.  Due to the fact that the cylinder in the other Silver Star was just a push fit, perhaps there may be a bit of grunge on both the cylinder and the case.  I may clean these parts to where they are clean and try again.  In the past, I fitted the engine with a light interference fit by placing cylinder in the freezer and the case in the oven  prior to fitting them into the engine. This gave a brief time to align the ports with the cutouts in the case.  Heating the two parts permitted easy disassembly.
      As things stand now, there is no way that the cylinder is going to enter the case!!!
      Suggestions and/or suggestions???
        Tia,
        Frank McCune
« Reply #14 on: November 20, 2018, 04:12:38 PM »
"  How tight should the cylinder fit into the case?  Is it  light interference fit? If so, how do I accomplish this?  Randy. you warned me NOT shrink fit these engines together as I would never get them apart again.  Due to the fact that the cylinder in the other Silver Star was just a push fit, perhaps there may be a bit of grunge on both the cylinder and the case.  I may clean these parts to where they are clean and try again.  In the past, I fitted the engine with a light interference fit by placing cylinder in the freezer and the case in the oven  prior to fitting them into the engine. This gave a brief time to align the ports with the cutouts in the case.  Heating the two parts permitted easy disassembly.   "
Hi Frank
You are correct you should clean the parts very well, you can even sand the outside of the sleeve with 1000 grit, as many times it has corrosion, rust, or carbon, steel wool will work too  and  NO I did not warn you to not shrink fit a steel sleeve into a HP, You should not shrink fit  the  Brass sleeve, it should be a slip fit, the steel sleeve  needs to be a press fit,
If you take the cleaned parts of  the HP, and do as I described earlier in this thread "make sure the inside case is clean and smooth with no burrs, and also the outside of the sleeve, on a  HP you put the piston sleeve ring pin and all in the case at the same time, Heat the case and drop in the whole assembly, take care to make sure the ring gap is in the correct place, and  take care  to slide the assembly in straight where the exhaust port is lined up correctly,"
I have done this on 1000s of engines, and about a hundred HPs with a press fit, There has never been a problem with any of them.  I just clamp the engine lugg on one  side with a vise grip that has thin cardboard over the jaws, then I heat the case with a  REAL heat gun, or propane torch, ... it takes about 8 to 10 seconds with a torch, then drop in the complete piston sleeve rod assembly, if there is no dings of debris, it should drop right in, and you will have a few seconds  to make sure the sleeve in in correctly.  You can call me if you have more  questions
PS  All of the  Sliver stars are supposed to be  steel sleeves
The  Gold Cups are the ones that had  the  ABC-R  setups ,  although I have seen  many with steel sleeves   and  I have even seen Silver Stars  with  ABC-R  in them
« Reply #15 on: November 20, 2018, 05:55:49 PM »
    How the cylinder fits is a function of what the materials are. There are some steel liner engines that need a tight fit against the aluminum crank case, so that you can get proper heat transfer for proper cooling. There have been lots of Super Tigres ruined by people sanding the cylinders for a slip fit, and then they never run right again.Next time you have some engines of different types apart, look and see the difference between the brass/chrome cylinders and the iron cylinders. Different materials have different rates of expansion and contraction.. I had a ST.46 once that I got from somewhere, and could not get it to run, like it wouldn't draw fuel. I finally took a real good look at the crank case, and the bottom was cracked, with what looked like vise jaw marks on it! The previous owner had obviously used a vise to push the cylinder liner in. This was before the internet, so I had to make a few phone calls to find out the correct procedure (Thank Tom Lay!, pulled the engine back apart, welded up the cracks, re-assembled and that engine ran in a Chipmunk for many years after that. Tom wasn't too sure I would get away with welding the case, but if it was broken already, what did I have to lose! I really try to resist taking any engine apart unless it's absolutely necessary. Just try to take care of them and feed them right and they tend to last a long time.
« Reply #16 on: November 21, 2018, 02:44:39 AM »
Motorman,
I agree with you that the effectiveness of chilling the sleeve is less than of heating the aluminum, and that condensation is a nuisance. However, to extrapolate this to the conclusion that it will also "...give you less working time..." isn't true. The conductive heat transfer coefficient is not different for the two cases, so for a given initial temperature difference, the working time will be the same. But if you need an extra bit of clearance for assembly (for sleeves or bearings, for example) and you do not want to go above say 350F oven soak temp for the case, then the additional shrinkage provided by chilling the sleeve can make a difference. If you have found it unnecessary then that is great. But that day may come when you need the extra clearance, and there is no question that it works.
For production installation of precision bearings, it is desirable to set the bearings on a metal hotplate while you work. The shaft goes in a fixture, which may or may not be part of a hand-press setup. Just pick up the bearing (white glove time) and drop over the vertically oriented shaft and let it drop into place. For some fits, and long engagement lengths (not recommended!) it may require a sleeve tool in the quill to ensure it is seated before it snugs up. The sleeve only contacts the race involved in the fit. When absolutely necessary, some operations may use LN2 on parts before assembly. Don't count on these coming apart without destruction of the lesser (cheaper) part. It may take EDM to salvage the high value piece. For modelers, on the basis of cost we'd chuck the thing out. On the basis of determination and curiosity, we tend to keep trying until it is undeniably junk.
« Reply #17 on: November 30, 2018, 02:57:06 PM »
     Up date on HP .40 cylinder R&R.
     I took a few minutes to clean all of the crud and corruption from the outside of the cylinder and the inside of the case and that appeared to solve the problem of R&R.  Now to pull the cylinder, one only has to heat the case and cylinder to 300 degrees F and it slides in and outs very easily.  One must hurry as a shrink fit happens very quickly.
        Thanks for all of the replies,
        Frank
