  • July 09, 2025, 03:08:18 AM
Author Topic: Engine parts  (Read 1910 times)
Engine parts
« on: July 28, 2006, 12:23:31 PM »
OK, I need to find a new crankshaft for a Magnum 53. Since these are discontinued, any ideas where I can get one?
Offline Tom Dugan
Re: Engine parts
« Reply #1 on: July 28, 2006, 05:00:43 PM »
Randy,
I checked the website and they dont list a 53 crank but they have contact info.  Maybe they can help if you contact directly.  http://globalservices.globalhobby.com/part/partsndx.asp
Thomas
Online RandySmith
Re: Engine parts
« Reply #2 on: July 28, 2006, 09:09:36 PM »
Hi Randy
I am a dealer for these  and  I checked for you, there  are  no crankshafts  for that motor  shown  any longer, You will need  to find a  used  one  somewhere??EBAy?
Re: Engine parts
« Reply #3 on: July 29, 2006, 12:11:06 AM »
Randy,
I was afraid someone would say that. The ASP 53 is the same engine. Maybe those are still around.
Edit
OK, I checked Hobbypeople and they sell a crankshaft that is advertised as a Magnum XL 40-53 crankshaft. I assume this is the correct one. The 40, 46 and 53 use the same crank? Hmm.
Re: Engine parts
« Reply #4 on: August 01, 2006, 05:13:35 PM »
According to Hobby People, this is the correct crankshaft. cool.
Offline Manuel Cortes
Re: Engine parts
« Reply #5 on: August 02, 2006, 06:13:46 AM »
I can confirm that .40, .46 and .53 use the same crank. Really is the same engine with diferent bore!!!!
Regards from Spain
Re: Engine parts
« Reply #6 on: August 02, 2006, 11:37:33 AM »
The crank is on the way. I'll pick up new bearings at the local bearing supply place next week. I have plans for this engine and need to it run again.  :)
