  • July 14, 2025, 02:29:17 PM
Author Topic: RoJett76 tank size  (Read 1232 times)
Offline Matt Piatkowski
RoJett76 tank size
« on: December 14, 2015, 12:54:12 PM »
Hello,
Is 8 fl.oz tank sufficient using 10% Nitro fuel to fly full pattern with RoJett76 having the Dub Jett provided unmodified black venturi and turning 13x5 two blade prop?
Matt
Re: RoJett76 tank size
« Reply #1 on: December 14, 2015, 01:07:46 PM »
Matt my ROJett .76s (3) use a .205 venturi over the .183 stock unit.  I use a three blade Mejlik 12.5 prop and have to remove fuel from a seven ounce tank to keep from overrunning.
