  • June 13, 2025, 02:47:19 AM
Author Topic: ROJETT Weights  (Read 2187 times)
John Leidle
ROJETT Weights
« on: September 18, 2014, 01:54:17 AM »
  Does anyone know what a ROJETT  76 & or 65?
Re: ROJETT Weights
« Reply #1 on: September 18, 2014, 04:17:10 PM »
The RO-Jett .76 is 355.5 grams (12.54 oz) with the two header screws, but no header, no spinner, a standard prop nut and a rather small washer.
As I understand it, the .65 isn't made anymore, but the .61 is, and a newer .67 is apparently built on the .76 case.
 H^^ Steve
Offline Balsa Butcher
  • High Desert Flier
Re: ROJETT Weights
« Reply #2 on: September 18, 2014, 05:52:14 PM »
Actually the .67 is built on the 61/65 case but has a larger cylinder. Interchangeable, mount wise with the 61/65s. When I get 'roundtuit I'll dig mine out and weigh it. Should only be slightly heavier than the 61/65s. 8)
« Last Edit: September 18, 2014, 07:23:43 PM by Balsa Butcher »
Pete Cunha
Sacramento CA.
AMA 57499
Re: ROJETT Weights
« Reply #3 on: September 21, 2014, 05:31:27 PM »
I wonder if Dubby could convert a .65 to a .67? Tho most .65's got converted to .61's, the 2-piece barstock cases might give some options. Dubby converted a .76 side exhaust to rear exhaust for me, and pretty inexpensively.  y1 Steve
Re: ROJETT Weights
« Reply #4 on: September 21, 2014, 07:33:22 PM »
The .65 is/was a .61 sleeve bored larger.  The issue was the sleeve got too thin with the .65 with really no more power.  I doubt a .67 is viable with the .61 sleeve.  I would be inclined to stick with the proven designs that have been de-bugged.  I've not used the .67 but consider my BSERE .40s, .61s, and .76s the best engines I have.  That .40 I think would make the best Classic engine you could get.  Awesome power in a .25 sized case.  Very light.
John Leidle
Re: ROJETT Weights
« Reply #5 on: September 22, 2014, 06:11:53 AM »
   Hi Dave ,  I believe the .67 is a stroked . 61  ,,,not gonna bet my SSI check on it but I believe that is what they did. I going to order a .76 today,  thank you for your help. D>K
Re: ROJETT Weights
« Reply #6 on: September 22, 2014, 10:22:43 AM »
The RO-Jett 76 and the RO-Jett 61 both have the same mounting dimensions.  I built a couple full body planes for the 76, but later dropped in a 61 (complete with 2 1/2" spinner) without modifications to the plane. (the balance was better!)
