  • June 18, 2025, 04:08:36 PM
Author Topic: RO-Jett prop?  (Read 1067 times)
RO-Jett prop?
« on: December 18, 2009, 11:32:46 AM »
This Hurricane stunter has RO-Jett 61 and I've used only a Master Airscrew 12-6 on it.  Although the plane doesn't seem to lack authority in most maneuvers, I think a different prop might improve matters a bit.  I haven't tried any other props and perhaps some good advice would save me time experimenting?  What might I try next?
Re: RO-Jett prop?
« Reply #1 on: December 18, 2009, 07:26:38 PM »
   This is with a conventional header muffler?
Re: RO-Jett prop?
« Reply #2 on: December 19, 2009, 12:36:57 PM »
I want to know about the Stalker .51RE prop question you posted a month or two ago. Did you find anything better, or even try any of the suggested props?  If you found something that worked, please report. If you didn't try anything, because it wasn't available at the LHS, then there seems to be nothing to be gained from this post.
 R%%%%
