  • June 18, 2025, 02:28:43 PM
Author Topic: Thunder Tiger GP42  (Read 984 times)
Offline Robin_Holden
Thunder Tiger GP42
« on: November 03, 2018, 07:35:03 AM »
Good day from North Yorkshire , England.
Is anyone using the TT GP42  for stunt ?
I’ve converted one , drilled the case for a spray bar / NVA assembly and have installed a suitable venturi.
What prop’ do you suggest ?
What take-off rpm setting ?
What fuel do they like ?
Any contributions much appreciated.
Robin.
Offline Dane Martin
  • heli pilot BHOR
Re: Thunder Tiger GP42
« Reply #1 on: November 12, 2018, 08:38:54 PM »
Well, if it helps...
The 42 looks to be a bit of work, given you must drill the case. The OS venturi (20-46) fits just fine. I personally would set it up how people have successfully set up the LA 40 or LA 46.
The 42 is a high Rev engine. For RC, there's some pylon race guys who love them, although may not be legal for many events. It's been a long time since I hung around with them.
I've had plenty of success with the 40 LA run with a TT 11x4.5. You might look into the 12x3.75 APC also. The 42 does like to Rev.
