  • July 15, 2025, 07:47:38 PM
Author Topic: Ringed engines for stunt?  (Read 2188 times)
Offline Andrew Tinsley
« on: July 14, 2014, 08:11:53 AM »
Hello engine experts,
Ringed stunt engines have always had problems with ring fits. It turns a good engine into a heap of rubbish, if the fit isn't good. I have had problems down the years with the likes of the ST60 and big Mercos. You can hone the bores, get good rings from Frank and carefully fit them, some running in and hey presto a really good stunt engine.
However sooner or later (usually sooner from my observations of others) the ring seal goes and the engine is all over the place with power down and also in the wrong places.
Now I have been watching some helicopter drivers. They use ringed engines because of the "harsh environment" they have to operate in. Well that is the reason most heli pilots give. Now these engines seem to go on for a very long time without any apparent performance drop. It seems to me that they last far longer than our stunt engines do?
So is there any advances in ringed engines for helicopters over our old stalwart ringed stunt engines? It seems to be the case (that word "seems" because I can't be sure) or is it simply that the helis are vastly overpowered and the average pilot wouldn't notice the drop off? They simply open the throttle a bit wider.
I can't imagine much advance in ringed model engines, but you never know until you ask the question.
Andrew.
BMFA Number 64862
Re: Ringed engines for stunt?
« Reply #1 on: July 14, 2014, 11:33:32 AM »
I think my problem with fitting rings is I set the gap to tight and when I run them in it wears right where the gap is as they expand when heated up from running. I have noticed when I set the gap a little more that they wear in and run for a long time. Maybe it is just me.
« Reply #2 on: July 14, 2014, 01:08:51 PM »
The demands we put on stunt engines are unique, and the outcome that's most important to us -- that the engine self-regulate -- is going to be far down on a helicopter pilot's list of desirable engine characteristics, because if he's serious he's using an engine speed governor.
So it may be that a ringed engine can easily settle into a state where it pumps out reliable power but, on its own, will never go the same speed twice.  That's death to a stunt engine, but may never even be noticed in a heli engine.
Online Steve Helmick
« Reply #3 on: July 14, 2014, 01:34:46 PM »
I read somewhere the reason Heli engines are ringed and not ABC or ABN. The story was that with the latter, when the throttle was reduced suddenly after a period of high throttle, the engine would cool down quickly and seize. It sounds fairly reasonable. Perhaps the cooling system and oil just isn't very good? They do use that Low Viscosity oil, for some reason. I would guess that a ringed P&L is more expensive to manufacture than an ABN, so don't reckon it's 'cause they're being cheap.   H^^ Steve
Offline L0U CRANE
« Reply #4 on: July 14, 2014, 05:53:44 PM »
Andrew,
Other than the difference between iron traditional square section and newer iron Dykes L-section rings, the difference may be in how we run engines, compared to helicopter fliers.
Dykes rings' L-section form applies combustion pressure inside the upright of the L-form to seal to the sleeve. Traditional square-section rings do the same, but not as well - they rely more on their own 'spring pressure' to retain working contact with the sleeve.
Running conditions differ too. Helos generally have plenty of throttle activity, so steady-state conditions are relatively rare. We want a smaller range of load conditions, unrelieved by occasional lightening of load and variation of RPM. From the exhaust trails I've seen in occasional glimpses, and videos, of helos, they generally run richer than we do - also good for ring life.
I have no idea of the duration of typical helo flights, but we know we need at least 6 solid minutes of consistency at a single "throttle" setting. That, too, may enter consideratiion.
\BEST\LOU
Offline Jim Thomerson
« Reply #5 on: July 14, 2014, 06:52:37 PM »
Only ringed engine I have flown stunt with was a K&B 4011.  I found, as time went by, more prime was needed for one flip start.  Put a new ring in and prime went back to small, and I maybe picked up a little power.  They ran to suit me.
« Reply #6 on: July 14, 2014, 07:57:52 PM »
I have used ringed stunt motors of one kind or another since got my first ST46 as a young teenager. I still run ringed stunt 4 strokes today.
« Reply #7 on: July 14, 2014, 08:38:27 PM »
I have a friend that use to fly YS 120 four strokes in R/C pattern. He noticed that his engines would sometimes loose power in mid flight and then it might come back or not by the end of the flight. One day he landed when the engine was putting out good power and pulled the cyl. to see where the ring had settled. He then worked out a way to pin the ring in that position so that it could not turn. After that he never experienced the power loss thing again. I am guessing there is always a little piston rock in the cyl. and by putting the ring gap in the best position it would hold compression while running. He told me at one time where it worked best to put that gap but I do not remember. It was either on the intake side or the exhaust side as I remember.
Online Brian Hampton
« Reply #8 on: July 15, 2014, 09:34:43 AM »
My first ringed stunt engine was the Enya 45 model 6001 (early twin ringed version) and I had to put new rings in it after only about 200 hours because it wasn't starting first flick anymore. Next was an ST G51 which had about 40 hours on it (still one flick starter and dead reliable) before I went to my current Enya 61RE which so far only has a bit over 10 hours on it. I've never had a stuck ring (or any ring problem) using all castor fuels.
