  • July 08, 2025, 06:25:43 PM
Author Topic: Replacement wrist pin pads  (Read 956 times)
Offline Mike Greb
« on: July 06, 2020, 06:57:13 PM »
I am working on  a motor that has  plastic wrist pin pads that are worn out.    What would be a good material to make replacements from?  I am thinking about using delrin (Acetel) , but I was wondering if there is something better. The liner is an ABN
Offline pmackenzie
  • Pat MacKenzie
Re: Replacement wrist pin pads
« Reply #1 on: July 06, 2020, 07:00:38 PM »
Teflon is higher temp than Delrin.
MAAC 8177
Offline Mike Greb
« Reply #2 on: July 06, 2020, 07:07:44 PM »
I just looked on the mcmaster-carr website and they list  PTFE rod that has a temp rating up to 500f .
Offline pmackenzie
  • Pat MacKenzie
« Reply #3 on: July 06, 2020, 07:11:26 PM »
Teflon is very easy to machine, much like Delrin.
MAAC 8177
« Reply #4 on: July 07, 2020, 03:36:45 PM »
Use  either one,  they both work OK
« Reply #5 on: July 07, 2020, 10:26:09 PM »
I have used the PTFE from McMaster. It is very soft. Once you turn the diameters, just slice it off to length with a good Xacto. Much better than trying to part it off. If you use nylon, use the Delrin, not 6/6 or the like. The Delrin machines mucho betterro.
Of course, if this is all old news to ya, forgive my comments, Big Mike!
The Divot
