Engine basics => Engine set up tips => Topic started by: kevin king on January 23, 2023, 10:49:16 PM
Nice. The replacement fox nva are good to know too!
These will work but they require the venturi area a bit so you get better fuel draw be less power then the ones that Randy S sells that have the same end diameter but a reduced center to match the original FOX NVA diameter.
Best, DennisT
Looks like they include some sort of plastic washers for each end. Maybe that works, but I tried that (not with RSM plastic washers), and the entire spraybar turned when I was adjusting the NV. Not what you want, OBTW. n1 Steve
Does Randy Smith still sell his PA NVA for the fox?
No, he doesn't. I called and asked him before Christmas.
Joe Ed Pederson
My original Super Tigre NVA Fox 35 ran great. If drilling the case to get it in was needed, and it restricted the venturi a bit, I didn't mind. Fuel draw, economy were great. I miss that engine. Also had a good fitting chip muffler. Probably a 50th or 60th Anniv. Thought I'd never fly Fox 35 again. Now I am rigging advanced trainers setup for Fox.
Back to the NVA, I'd say an original Super Tigre or an RSM would be fine, even an Enya if that's your style.
Peter
