  • June 27, 2025, 09:04:09 AM
Author Topic: RE engines???  (Read 7522 times)
RE engines???
« on: November 27, 2011, 07:17:54 PM »
Other then the Ro-Jet and the PA series engines, what other RE engines are there?
Offline Martin Quartim
    • StuntHobby
Re: RE engines???
« Reply #1 on: November 27, 2011, 07:42:42 PM »
Stalker, Retro and hopefully Enya will soon have the 61CXR R.E.
Enya has a  53 4Stroke engine that can be setup for R.E.  Here is a picture of the engine in a SV-11
Martin
Re: RE engines???
« Reply #2 on: November 27, 2011, 08:08:31 PM »
  40/46VF - still the gold standard.
Offline Chris Wilson
Re: RE engines???
« Reply #3 on: November 27, 2011, 08:55:23 PM »
MVVS engines between a 0.15ci and the mighty 0.91.
Fox 25.
R+B 75.
Merco 40, 51 and 61.
PAW diesels can be made to 'pipe' towards the rear.
K+B ducted fan engines.
And various odds and sods like the Super Tigre X40, OPS engines, some Rossi's, Russian Stass's, and well - most marine conversions as well as a lot of modern combat engines.
MAAA AUS 73427
Offline Brian Hampton
Re: RE engines???
« Reply #4 on: November 28, 2011, 07:22:23 AM »
I guess that makes the Irvine 40RLS the platinum standard then :), it's a sweetheart of an engine. And yes, I have the 40/46VF's as well. As for the Stass's 42RE, I'm actually quite impressed by it, even with its plain bearing crank and iron piston, although I'm beginning to think I've got the only one in the world because no-one seems to know anything at all about it.
Re: RE engines???
« Reply #5 on: November 28, 2011, 02:27:25 PM »
Someone forgot Rossi and OPS
Re: RE engines???
« Reply #6 on: November 28, 2011, 03:00:23 PM »
No, not really (check my last post!)
MAAA AUS 73427
Offline Russell Shaffer
Re: RE engines???
« Reply #7 on: November 28, 2011, 03:49:01 PM »
Fox 25 BB.  The cylinder can be turned in 90 degree steps, even point forward.
Russell Shaffer
Klamath Falls, Oregon
Online Tim Wescott
Re: RE engines???
« Reply #8 on: November 28, 2011, 04:07:26 PM »
Would I be too much of a smart a** if I were to point out that a muffler on a Cox 049 would...
Oh, never mind.
Re: RE engines???
« Reply #9 on: November 28, 2011, 04:32:24 PM »
Ah, I covered that one also!
MAAA AUS 73427
Re: RE engines???
« Reply #10 on: November 28, 2011, 08:55:24 PM »
Surely there must be some more rear exhaust engines out there?
How about the Enya 21 CLX, OS Max 46 VX, OS Max 21/25 XZ, Picco 21/45/90R (in fact the entire Picco range), and the best for last - the stunt Cyclon 60!
http://www.rusengines.ru/?lang=en
MAAA AUS 73427
Re: RE engines???
« Reply #11 on: November 29, 2011, 03:23:43 PM »
Hi Chris   I was only speaking of motors that worked for CL Stunt
There were special OPS SPA CL engines made for Stunt C/L that worked very well, many  people used them, and the Rossi 45 worked very well also
Maybe the St X40 worked OK..but the noise at 16,000 Rs  was  baddd   :( :o     and the COX maybe as a stretch  LL~
Offline Mike Greb
Re: RE engines???
« Reply #12 on: November 29, 2011, 04:34:43 PM »
If you look around, you could find one of the fine Fox rear exhaust 36 with the can muffler!
Re: RE engines???
« Reply #13 on: November 29, 2011, 05:38:11 PM »
Hey Randy,
                  yeah, I was just spewing out names back there but the more you dig the more you find and surprisingly enough there are quite a few RE engines out there!
The Super Tigre X40, have a mate with two of these and he would like to try one on a pipe some day - but probably not at 16 000 rpm though!
The OPS stunt engine, never seen or heard of one but then I have never seen an HP Gold Cup special used in stunt either but I believe that they were.
Cheers mate.
MAAA AUS 73427
    • StuntHobby
Re: RE engines???
« Reply #14 on: December 01, 2011, 03:01:47 PM »
At the time of the 40/46VF there was the Enya 45CXL, AAC construction, lighter then the VFs and with 144 exhaust timing. Unbelievably, seems no one has used this engine in C/L. Perhaps some in Downunder or Japan may have used one, who knows?
Martin
Re: RE engines???
« Reply #15 on: December 01, 2011, 03:54:56 PM »
   I recall someone trying it, but I can't recall the results. Enya doesn't have much of a rep in US stunt circles, and when you have an essentially perfect VF setup, and then PA and RO-Jetts, not a lot of motivation to go way off the reservation.
Re: RE engines???
« Reply #16 on: December 01, 2011, 03:58:44 PM »
Whats the deal with the VF nowdays. Does OS still make them. If I am not mistaken, that was an "adapted" ducted fan setup that hit the big time in f2B.
Re: RE engines???
« Reply #17 on: December 01, 2011, 04:07:42 PM »
Hey Randy,
(snip)
Cheers mate.
Hi Chris,
I have a new Gold Cup .40 that will be in a plane next season.  It is NIB but came from the factory missing the ring so I got it real cheap.  It has been set up for stunt.
Big Bear
Re: RE engines???
« Reply #18 on: December 01, 2011, 07:26:06 PM »
Here's an older RE Supertiger.
Yes, believe it or not, I'm considering strapping it on to something. Undecided?
CB
Re: RE engines???
« Reply #19 on: December 01, 2011, 08:25:18 PM »
Leo O'Reilly of Modelflight here in Adelaide was the agent for all Enya engines into Australia. I asked Leo if he would get a few in his next order but he couldn't do it because there was a minimum number of any engine required so they were never seen here. It's a shame Enya wasn't promoted better in the USA back in the 70's because they were at least the equal of the ST's for stunt (by which I mean the Enya 45 model 6001).
Re: RE engines???
« Reply #20 on: December 01, 2011, 11:28:12 PM »
   I think there were originally intended for small pattern airplanes. There were ducted fan versions of them but I think they were modified from the pattern version, not the other way around.
    They haven't been made for at least 20 years and it may be bordering on 25. The reason we (well, I) still discuss them is that they are still widely available, and in many ways they are the standard by which the others are judged. We are still designing to the same standards - David's current airplane is for all intents and purposes is indistinguishable from an early 90's classic West coast 40VF plane. Keep it in the 60 oz range with a 40VF and you are giving up NOTHING as far as flight performance goes. In about 5 minutes there will be a bunch of people saying how stupid I am for saying that, but none of those people have managed to beat Paul Walker and his Impact/40VF , either. I may have lost track of it, but I think the *exact same airplane* won the 1990 and 2005 NATs. So we haven't managed to do any better over around 2 decades of trying.
    I like the particular version and setup of the RO-Jett 61 entirely and precisely because *it runs like a gigantic 40VF*. In fact as soon as the Sun came out at this years TTs I wish I had brought a 40VF with me. At least I would have remembered how to set the needle, which is better than I managed with the 61 this time around!
Re: RE engines???
« Reply #21 on: December 02, 2011, 08:48:34 AM »
HI brett,
In my current situation, I am glad I kept my .40VFs!  We have a few PAs, but they will still be a while before any new ones are made..  I haven't used a RoJett, but that's just because I have only bought one "new" PA!  If I could find a good used Ro Jett at a reasonable (to me) price, I would try one.
I hope to rebuild my 1996 NATS plane and it used a .40VF, so it will again.
Re: RE engines???
« Reply #22 on: December 02, 2011, 09:06:43 AM »
    They haven't been made for at least 20 years and it may be bordering on 25. The reason we (well, I) still discuss them is that they are still widely available, and in many ways they are the standard by which the others are judged. We are still designing to the same standards -  Keep it in the 60 oz range with a 40VF and you are giving up NOTHING as far as flight performance goes.
This cat is still current -Not happenin?
Re: RE engines???
« Reply #23 on: December 02, 2011, 09:23:27 AM »
Hi Milt,
The DF suffix might mean a much higher timed version.  The original OS .40VF was also made in a "DF" (ducted fan) version but not used for stunt that I know of.
Re: RE engines???
« Reply #24 on: December 02, 2011, 09:23:44 AM »
   It's not the same. No one has bothered trying any of the newer-era OS engines, that I am aware of, since we all have PAs or RO-Jetts, with drawers and drawers of 40/46VFs rusting away if necessary. It may work but no one knows, and given that it would likely take roughly a year on average to work out a good setup for any new engine which may well turn out to be a waste, not a lot of motivation.
   Everybody wants to fly electrics next anyway.
Re: RE engines???
« Reply #25 on: December 05, 2011, 02:28:17 PM »
Looks a lot like my MVVS 51!
MAAA AUS 73427
Re: RE engines???
« Reply #26 on: December 05, 2011, 03:58:17 PM »
This is going to be famous :) L
Looks like a Belko
Offline ash
Re: RE engines???
« Reply #27 on: December 06, 2011, 06:19:14 AM »
Metkemeijer?
It looks like a giant F2C engine!
Re: RE engines???
« Reply #28 on: December 06, 2011, 10:55:39 AM »
Hold up, not "everybody"....... >:D
Derek
Re: RE engines???
« Reply #29 on: December 07, 2011, 11:50:10 PM »
Stalker .61 LT Longstroke is a nice little engine for RE. Wouldnt use it on anything larger than a classic ship.
Thats just me.
Derek : You mean your not sold on electrics??
Offline Andrew Tinsley
Re: RE engines???
« Reply #30 on: December 08, 2011, 04:01:20 AM »
I am with Derek on this one! I like cranky, dirty, IC engines. They are the main reason that I fly. If I had to fly electric, then I would give up. I am never going to win any competitions because I don't enter them. I am sure that there are many sports flyers that think the same way!
Andrew.
BMFA Number 64862
Re: RE engines???
« Reply #31 on: December 08, 2011, 04:30:20 AM »
Thats just me.
Ha Ha, I assume that was a joke PJ? I am with Andrew on this, I like the smell, sound and feel of IC. (no, I still have not flown an electric, I am sure it feels fine...)
D
Re: RE engines???
« Reply #32 on: December 08, 2011, 05:12:26 AM »
You know it was derek!
 ;D
I like a smoke trail!
Re: RE engines???
« Reply #33 on: December 08, 2011, 06:30:42 AM »
Well, I have seen electrics make those. The only problem is when they let out all their smoke they don't work anymore. LL~
Offline Ward Van Duzer
Re: RE engines???
« Reply #34 on: December 08, 2011, 07:11:31 AM »
In all this rhetoric did I miss the OS .25 VF? Even Randy didn't mention it...For shame!
And for all those "newbes", it was the OPS .40 that started all this insanity!
W   n~
Offline Steve Fitton
Re: RE engines???
« Reply #35 on: December 08, 2011, 12:56:08 PM »
W   n~
What do you do with a VF 25?
Re: RE engines???
« Reply #36 on: December 08, 2011, 03:37:30 PM »
Hi Steve,
You put it in a Stunter of about 50" span, with a pipe.  One has been published in FM (Eliminator) and planes like the Ares/Perroquet/Gieseke Nobler go extremely well with the .25VF piped set up. ;)
Big Bear
Re: RE engines???
« Reply #37 on: December 08, 2011, 04:39:51 PM »
.............what other RE engines are there?
Taipan 3.5 glow (paradoxically the rare Taipan 40 really was a front exhaust!)
MAAA AUS 73427
Offline David Zwolak
Re: RE engines???
« Reply #38 on: December 08, 2011, 06:31:51 PM »
From where, or who, are Stalker RE engines available now?  I heard a model builder in Canada was supplying them to the US for a while on special order.
Re: RE engines???
« Reply #39 on: December 08, 2011, 06:33:38 PM »
Hi David,
Kaz Minato is a distributor and a great guy to work with.  I don't have his contact info but I know plenty of people here do have it.
Re: RE engines???
« Reply #40 on: December 09, 2011, 04:26:55 PM »
I get my Stalker engines from Kaz - However I only use them for Classic now.
Derek : Tisk tisk...  n1  ;D
Offline Balsa Butcher
  • High Desert Flier
Re: RE engines???
« Reply #41 on: December 09, 2011, 05:37:35 PM »
Alan Resinger is the Canadian source of Stalker engines. I bought a 51 from him and am very satisfied. I think he can be contacted on this forum through the members listing.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Re: RE engines???
« Reply #42 on: December 09, 2011, 06:49:52 PM »
I have quite a few RE engines (Irvines, OS, Stalker, Stass's, Taipan) but my latest is this Torpedo Special "Twin Stack" from the late 40's.
    • StuntHobby
Re: RE engines???
« Reply #43 on: December 10, 2011, 05:55:53 AM »
Hi Brian,
please post some pictures of the Irvine and Stass. Have never seen one of those.
Martin
Enya 45CXL AAC
Re: RE engines???
« Reply #44 on: December 10, 2011, 07:34:21 AM »
The Irvine 61 is brand new and uses a Dykes ring, later versions were ABC and I think had a red head. The Irvine 40RLS uses a stunt timed liner and the red head to distinguish it from the normal RC version. AFAIK mine is the only one in Australia and it's the one used by Derek Pickard in a report he did for Aeromodeller magazine on piped engines for CL stunt. The SE exhaust Stass's is relatively common (they're listed on the Carlson site) but the RE version seems to be extremely rare, no amount of Googling finds any mention of them and I've asked on every forum but no-one has heard of them. I still have one lead to follow up on though. Note that the name is actually Stass's as can be seen on the crankcase. Apparently the RE was made for CL use only. One photo shows it with its exhaust stub in place.
Re: RE engines???
« Reply #45 on: December 10, 2011, 11:13:28 AM »
Hi Pete,
I wasn't aware that Alan was a distributor for Stalker!  He IS a member here.
    • StuntHobby
Re: RE engines???
« Reply #46 on: December 11, 2011, 04:33:36 PM »
Hi Brian,
Thanks for the nice pictures. The Irvine engines looks very interesting.
Martin
Offline Allan Perret
  • Proverbs
Re: RE engines???
« Reply #47 on: December 12, 2011, 08:14:22 AM »
Hi Brian,
Martin
Enya 45CXL AAC
45CXL, is this a current engine with Enya ?
Allan Perret
AMA 302406
Slidell, Louisiana
John Leidle
Re: RE engines???
« Reply #48 on: December 17, 2011, 08:30:20 AM »
 I have purchased 2 Stalkers from Alan. Quick turn around .. nice guy.
Re: RE engines???
« Reply #49 on: December 19, 2011, 05:21:54 PM »
AP Hornet 09 and 15.
MAAA AUS 73427
