  • July 17, 2025, 08:08:36 PM
Author Topic: Rattler Topedo/St .29 Hybrid.  (Read 988 times)
« on: October 19, 2007, 04:01:42 PM »
a/.  apparently one fits a St piston liner to a K&B Torpedo .29 case.
b/.Now apparently theres a few differant .40 cases . Anyone documented
the changes to the bypass passage.
c/.One presumes an early case with a small bypass would be the trick for a stunt .40 topedo .?
 Back to a/.  - any dead .29 Torpedo FR or RRs in the cupboard ?
Re: Rattler Topedo/St .29 Hybrid.
« Reply #1 on: October 19, 2007, 09:41:34 PM »
Early Rattlers were K&B's with ST piston/cylinder and rod. Later, they made their own sandcast case, front end, and I think, back cover. The internals were still a mix of K&B and ST parts. We had at least 3 of these, here in the Pacific Northwest part of the USA. I was tied by one on one occasion, otherwise, as I recall, somebody with a ST .29rv won, mine or somebody else's. The ST's didn't break anything, except pistons, on occasion. I got best results by putting in a K&B .40 venturi, and lowering the head .040", 65%-75% nitro. Lots of power, but some safety margin. Parts were hard to get, even then. It's why I finally gave up and flew F1A for 15 years.
Later .40's got bigger bypasses, of course. Around '69 or '70, they got a squish head. I reworked a '67 .40FI for a FF buddy. It ran 18k on an 11-4 RevUp and 30% nitro. He said it was faster on that prop than the "Snarly Ported" K&B .40's, which isn't a complete surprise. It really howled on an 8-8 TF Speed Prop on 40%!
I tried a K&B .40 (#4055, late model stunt version). Not much power, incredibly heavy, what more could you not want? I sold two NIB and gave the used one away.
No, but be aware that the FR and RR .29 had different strokes, with the FR being longer, so if you made a FR hybrid with ST piston set, you might end up with over 5cc's.
H^^ Steve
