  • June 20, 2025, 01:44:20 AM
Author Topic: Saito 40 problem  (Read 2241 times)
Offline Sam Laughery
  • ACE
    • laurelhighlandsrc.com
Saito 40 problem
« on: April 25, 2006, 05:05:08 PM »
I have a Saito 40 on an ARF Cardinal.  It ran perfectly last year with the following setup:  APC 12 1/4 X 3 3/4 prop, pressurised clunk tank mounted on center with the engine.  This was one of the best combinations I have ever used.  This year starting with the first flight it runs fine right side up, inverted the engine slows by at least 15-20%.  So far I've changed props (11 X 5 and 10 X 5) ,put on a wedge tank (and moved it up and down)  and taken off the pressure.  It runs exactly the same in every case.  It seems to perform better once I get below 1/2 a tank of fuel.  I'm on the verge of replacing the Saito with an OS 46.
Any suggestions would be greatly appreciated.
Sam
Alan Hahn
Re: Saito 40 problem
« Reply #1 on: April 26, 2006, 11:13:04 AM »
Here are a couple of shots in the dark.
1) Change glow plug
2) Measure valve clearance
3) check to make sure that oil breather/overflow isn't clogged up from last year.
It isn't obvious to me why these things would affect normal vs inverted flight, but it couldn't hurt.
