Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 06, 2025, 10:28:15 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
quick question on tank height
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: quick question on tank height (Read 1351 times)
rich gorrill
23 supporter
Trade Count:
0
Commander
on:
July 27, 2020, 07:04:32 PM »
Hi all, finished my Viking and on test flights engine went a little lean inverted. It's an LA40 mounted upright. Tank is mounted on the engine bearers held in place by cross bracing. question is do I have to raise the engine or the tank to cure the problem.
TIA
Rich
Logged
Peter in Fairfax, VA
24 supporter
Trade Count:
0
Admiral
Re: quick question on tank height
Reply #1 on:
July 27, 2020, 07:47:33 PM »
Raise engine or lower tank.
Logged
Dennis Toth
2020 supporter
Trade Count:
0
Admiral
Reply #2 on:
September 02, 2020, 12:11:42 PM »
Rich,
With the Viking I think you can just add a shim under the engine mount lugs, I would start with 1/32" brass or plywood (harden with CA) or plastic credit card stock.
Best, DennisT
Logged
Ken Culbertson
25 supporter
Trade Count:
0
Admiral
Reply #3 on:
September 02, 2020, 01:29:46 PM »
Even though I have gone over to the dark side I still have sympathy for those of you still facing the age old problem of needing to raise or lower the tank when you can't. Back in the stone age of the 70's I used to make my own tanks and I came up with a way to make the uniflow vent adjustable (sorry Matt). It is a bit of work to make but it worked. Sorry for the crude drawing.
Forgot - a short length of flexible tubing on the uniflow if you use brass. Copper bends easy enough and you can skip the tubing.
Last Edit: September 02, 2020, 01:50:54 PM by Ken Culbertson
Logged
Steve Helmick
24 supporter
Trade Count:
0
Admiral
Reply #4 on:
September 29, 2020, 11:29:57 PM »
If none of the above suits the OP, either making a new tank or modifying the existing tank's plumbing is another option. Especially easy if you are running a uniflow plumbed tank.
Logged
In 1944 18-20 year old's stormed beaches, and parachuted behind enemy lines to almost certain death. In 2015 18-20 year old's need safe zones so people don't hurt their feelings.
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Jump to:
=> Engine set up tips
