  • June 16, 2025, 09:33:41 AM
Author Topic: Question on the new .75 's from Randy S. and Richard O.  (Read 1215 times)
Offline Norvaldo
« on: October 16, 2006, 07:14:51 AM »
The PA Merlin .75 and the RO-JETT .76
I have read from other treads that these fit  a ST .60 mounting which  in mm is 20/44
However ; what about tank size ?
I have currently 6 OZ (one 6.5 oz) tanks in my planes.
Is that sufficient for a full pattern run ?
Norvald Olsvold
Online RandySmith
Re: Question on the new .75 's from Randy S. and Richard O.
« Reply #1 on: October 16, 2006, 11:25:50 AM »
Not really  you will need to plan  on an  8 ounce  tank,  athough  some  are doing the pattern on a little  less.  I need  7 ounces min.
The  PA 75  is the  same  bolt  pattern as  the  ST 60.  I do not know  about the  Jett
« Last Edit: October 16, 2006, 02:27:45 PM by RandySmith »
Offline Ron King
« Reply #2 on: October 16, 2006, 03:01:50 PM »
The RO-Jett 76 has the same mounting dimensions as Richard's other engines (51, 61, and 65). It is not the same as the ST 60.
I have flown the pattern with a six ounce tank and the RJ 76, but I don't recommend it. You have to choke the engine down too much.
Ron
Ron King
AMA AVP District 4
Wannabe Stunt Pilot since 1963
 Amateurs practice until they get it right; Pros practice until they cannot get it wrong.
Offline peabody
« Reply #3 on: October 16, 2006, 06:42:53 PM »
Winfred is flying a RO Jett 90 with a great big grin of late....
I have no idea what sized tank he is using...
