  • June 16, 2025, 09:35:24 AM
Author Topic: Super Tigre G21 40 Stunt  (Read 1656 times)
Offline Manuel Cortes
« on: October 15, 2006, 11:59:00 PM »
Hello all;
Some person has used this motor for stunt, or knows how well it works for our purpose?
There is a big diference with the beloved 46?
Thanks for your help.
Manuel.
Re: Super Tigre G21 40 Stunt
« Reply #1 on: October 16, 2006, 08:00:53 AM »
Hello all;
There is a big difference with the beloved 46?
Manuel.
Hi Manuel,
I have a 40, but have never run it in a stunt plane. :(
I guess the fact that it is the same case as a .46 and knowing what the .46 does, I just have not tried to see what it will do!
Bill <><
Offline wmiii
« Reply #2 on: October 16, 2006, 03:09:51 PM »
As I remember, very smooth, just not very much power.
 Walter
walter menges
Online RandySmith
« Reply #3 on: October 16, 2006, 03:59:49 PM »
Hello all;
Manuel.
Hi Manuel
There is  a  very big differance in teh 2  motors, the 46  will turn a  much larger and  a larger  range of props. with the  ST 40  it is  much more  narrow in it's  range,  for  stunt,
11 x5  is  a  good choice  and  you need  to run it harder  than a  ST 46, it  dies  not  4-2  nearly as  well  as  teh  ST 46
« Reply #4 on: October 17, 2006, 08:09:37 AM »
Thank you very much for your help!!!
Regards from Spain.
Manuel.
