  • June 21, 2025, 11:58:37 AM
Author Topic: Question on PA .61  (Read 1068 times)
Offline Norvaldo
Question on PA .61
« on: April 29, 2007, 01:42:53 PM »
Hi.
I have a PA .61 SE which i am running muffled with pressure.
I remember that Randy sent me some extra head shims which i mounted.
That was last year.
When checking today, i found that there was a total of 4 (four)  of the brass head shims plus the one fixed to the head.
This really sounds a bit much to me. I fly at sea level using 10% Nitro and 20% oil (75/25  synth/castor).
Maybe Randy have some ideas.
Norvald
Norvald Olsvold
Re: Question on PA .61
« Reply #1 on: April 29, 2007, 04:01:46 PM »
Hi Norvald,
Is there a problem with the way it runs now?  If so, please describe it.
The extra head shilms are always provided, as far as I know, in case you need to tune it to more nitro, soften the break, etc..  I do not know how many are in ours, but I just ask Randy if something is wrong with the way they are running (which ain't often!)
Bill <><
Offline Norvaldo
« Reply #2 on: April 29, 2007, 04:15:06 PM »
No..There is nothing wrong with the way it is running.
(My flying today ended with the engine not being able to get into 4 cycle at all, but that was explainable. A fragment from the fuel tube had got stuck in the needle valve. I must have used some wrong tool when i cut it.)
However:  I am the only one having this engine here in Norway, so i cannot judge exactly if it is running optimal.
I.m.o , even a not optimal PA .61 performs better than most others.
I just thought that 5 head shims sounds to be a lot..
Norvald
Norvald Olsvold
Online RandySmith
« Reply #3 on: April 30, 2007, 12:00:11 PM »
Hi.
That was last year.
Norvald
Hello Norvald
The PA 61 side ex  engines normally run with .020  to.028 thou head shims. It doesn't matter how many shims are there, the TOTAL of the shims are what counts, You may have several .003 thou shims in your engine.. or a .005 or  .008
And there is no shim that is  fixed to my heads, it just may be stuck, you should be able to remove it easy.
If the motor seems to need a little more punch in the manouvers, take out 1 shim, if it is a little too strong in the manouvers add 1 head shim, You can also "tune " the engine by adding or taking w\away nitro...IE: run 5% if 10 is making the engine come on too strong,  or  run 10% is 5% is just a little too tame or weak. any questions you have  please  just ask
Randyaero@msn.com
Offline Norvaldo
« Reply #4 on: April 30, 2007, 12:44:16 PM »
Hi Randy.
That was just what i was after..
You were right; it was not fixed, it was just a little bit stuck.
Tomorrow is holiday here in Norway and wether is perfect so i will spend the day flying.
Plenty of time for testing with  3 ,4 5 shims..
I will bring both 5% and 10% fuel with me.
Norvald
Norvald Olsvold
