Options, build a metal tank with the pickup coming out the back corner
build a tank that is wider than long so less distance to affect run
what is your intent, is this a sport model or something you imagine to be competative,, it makes a difference,,
or is it another display model?
Mark,
Now be nice, my models aren't display, they all will fly.
That sideways tank is a great idea, I'm glad I thought of it.
I'll have to take a good look at the drawings and see if I can apply your idea. A good one actually. See what I can do with it because room is an issue.
The model is designed for competitive stunt, not sport.
Thanks for the reply and the idea. You just may have solved this issue.
Charles
P.S.
OK, now you have me thinking.
I really don't want to make a tank so I'm thinking a clunk tank set sideways.
Then I won't need a pump, less plumbing and less to go wrong. KISS.
Thanks again Mark.
You actually made my evening.
