CLICK HERE--><--CLICK HERE
Proper procedure to replace plastic tee dee/medallion carb bodies?
Started by Michael LeGate, September 18, 2026, 03:04:27 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Michael LeGate
The parts are here from Mecoa. The plastic bodies cost more than the engines did when new (groan). I'm looking for the proper way to disassemble them to replace the carb bodies. I've got the single tooth spanner for the next part in, but not sure how the thrust washer comes off. Two screwdrivers ain't gonna cut it here.
Dave Hull
Remove the backplate.
Remove the cylinder. Don't use the tool that goes thru the exhaust ports. Hopefully you have a cylinder with flats on the top.
Remove the piston and rod from the crank.
Install a sacrificial prop screw, threading it in until it bottoms out.
Set the back of the case on a hard, flat surface like a cast iron saw table.
Tap the prop screw with repeated light taps using a brass mallet or small hammer. It should back right out.
Remove the crank.
Now unthread the nose retainer using your spanner tool.
Remove and replace the carb body/venturi (TeeDee or Medallion).
Reinstall the threaded nose retainer. Mongo torque on plastic is not recommended. The bodies usually split on the seam on the bottom.
Reinstall the drive hub being very careful with alignment. Use a spacer or prop and washer and screw to draw it down. Be aware that the undercut on the crank behind the knurling is the weak spot. If you only pick up a couple of threads, you are only pulling on this necked-down area. Using a threaded stud that is fully bottomed out and a nut is much preferred. After seating, check prop tracking to be sure you got it on straight.
As an alternative if you are able, machine a press-tool that goes into the rear of the case that contacts and fully supports the crank. Then you can use a press to reinstall the drive hub. The tool sits on the press table; the quill presses down on the drive hub. If you install a stud (not the prop screw) into the crank, then a solid drill press can be used for this operation with the added advantage of using the chuck to grab the stud for initial alignment. There is much less chance of getting things cockeyed this way.
Check again for debris. Oil. Reinstall rod on crank, cylinder on piston, backplate on case.
You can actually jack the drive hub off just by backing out the nose ring with the spanner. I wouldn't recommend that.
Michael LeGate
Thanks Dave. 3 more engines will be back in the operational arena  H^^
Dave Hull
This one is a Medallion .15, but they are all very similar. Oddly, this engine would not run on a profile plane--it wouldn't even start. Removed, it ran great on the test stand. I believe it was unrun when I got it. When I took it out of the test stand and looked very closely, I noticed that the venturi body was split along the mold seam on the bottom at the back. I got a new one from MECOA. It was a good thing I took it apart--the rod/piston slop was very large and it would have likely punched thru the piston in short order. It turns out that Cox never sold a rod reset tool for the .15.  So this project awaits my fabrication of a reset tool....
Motorman
All good advise above. Couple of things, Don't forget the fiber washer that goes on behind the drive washer. Some had steel washers there. Some drive washers don't seat down on anything. They don't go all the way in to the shoulder of the crankshaft. They depend on the prop hub being square to line up properly. A new Cox gray competition prop is pretty good for pressing. I made a thick aluminum spacer on my lathe but anything that's parallel like a maple motor mount stick with a hole for the bolt will work. Get the grooves in the drive hub lined up with the splines on the shaft before pressing. If you're using Tornado Black Magnum props expect tremendous wobble. I've never seen one of those props with a good hub.
Hope that helps,
Like Like x 1 View List
Mark Mc
I do one thing slightly different.  I take it all apart as described, but for tapping out the shaft I use a short and long 5-40 screw and an old prop.  Screw the short screw through the plastic prop (ideally a damaged prop that has had both blades removed) into the crank until just a couple of threads are showing.  Tap the screw head until the head is flush against the prop.  Back it out a couple more threads and repeat.  Do this until the short screw is backed all the way out and then start over with the long screw if/as needed.  This method prevents accidentally bending the screw while tapping.
