  • June 18, 2025, 09:15:51 PM
Author Topic: Brodak 25 VS LA 25  (Read 1337 times)
Offline Dick Pacini
Brodak 25 VS LA 25
« on: October 09, 2012, 05:48:54 AM »
I haven't been able to find much info on the Brodak 25.  Is it a decent motor? How does it compare to the LA 25?
AMA 62221
Offline Mike Greb
Re: Brodak 25 VS LA 25
« Reply #1 on: October 09, 2012, 05:54:41 PM »
Brodak is a better engine in my opinion than the la 25, if you can get your hands on one, out of stock for a long time.  The aac piston and sleeve are much more durable than the la.  It may seem a bit weeny with the stock venturi, but it can be opened up some if you need more power.  I just bolted mine onto a airplane and started flying it with a 9-4 prop. The third flight was an official OTS flight. After  a fair amount of flying old time stunt, it is now on a super slow rat with a .340 venturi.
