  • July 16, 2025, 02:14:47 PM
Author Topic: Prop trimming (shortening)  (Read 4195 times)
Offline Gil Mc Millan
« on: February 23, 2012, 11:58:38 AM »
Hi Everyone,
I hear "trim an 11x6 to 10 inches" mentioned frequently in this column & I have done it myself; but I searched & couldn't find any information on how prop trimming should be done correctly. I assume that it matters how the tips are shaped, the blade thinned.....etc. Are there rules of thumb on cause & effects of prop trimming ?
Also what effects on line tension, in both level flight & overhead, does diameter & pitch have ?
I'm just trying to learn, thanks for any replies,
Gil Mc Millan
Gil Mc Millan
AMA 914386
Re: Prop trimming (shortening)
« Reply #1 on: February 23, 2012, 05:41:35 PM »
I trim wood props mainly to increase RPM without losing very much blade area.
The most accurate way:  Use a disc sander.  Mount the prop on a board, using a 1/4" drill bit (or whatever fits the prop). Clamp board on the sander table.  Carefully rotate prop tip through the sand disc, taking off just a tiny bit at a time.  Repeat for opposite blade.
I leave the tips square, just as they come out of the sander.
« Reply #2 on: February 24, 2012, 01:17:06 PM »
Thanks for your reply Floyd, from your answer I assume that your telling me that the shape of a propeller tip isn't important, & that I dont need to be concerned with that.
Should I expect the same performance from a prop that was manufactured as a 10x6 as I would from an 11x6 that had 1/2 in removed from each tip ? ( assuming that both props were the same brand & style, & properly balanced)
As you didn't answer, do you not have any knowledge about line tension changes with prop diameter &/or p
Thanks again, Gil
Gil Mc Millan
AMA 914386
« Reply #3 on: February 24, 2012, 03:21:03 PM »
There was an article in Stunt News (late '90's?) about the effect propeller tip shape has on the model. More line tension in the overheads, better corner, etc. Can't say that I remember a lot about it, but the author seemed convinced enough. IMO, you can easily find enough variation between two seemingly idential propellers that one will work wonderfully and the other definitely not. What you do to the tip shape may have some effect, but probably not as much as getting that good one of the two.
That said, I attempt to keep the tip shape the same as stock, or close. One time, I trimmed one of my favorite props (a brand that is very well molded plastic and very consistently good), and it wouldn't even rev up as high as it did before I so rudely damaged it on takeoff and subsequently trimmed it down to make it useable. I've been clipping down props for about 40 years, and thought I'd done a decent job. I decided that the tip was left too thick. I will be more careful in the future.  D>K Steve
« Reply #4 on: February 25, 2012, 10:51:07 AM »
I think a lot depends on where the motor wants to run. I have found on my McCoy 40 Red Heads that a 12-6 APC cut to 11 works really well on them. I cut them on my band saw with a homemade jig. I leave the tips square except for just a slight rounding of the corners. The McCoy's like to be loaded, and don't like to run very fast, so the 6 pitch props work well. Most of the older baffle piston motors like 5 and a half to 6 pitch. Later more modern engines like less pitch. The diameter will also effect turn rate. More diameter will slow the turn rate, and less will increase it. But there are exceptions to every rule.
« Reply #5 on: February 26, 2012, 12:31:12 PM »
Pat Johnston is a master of carving props. He generally buys Zinger, BY&O or other props and cuts them to the length he wants. Zingers are nice because they are thick and have plenty of "meat" so you can repitch them pretty easily. Using a pitch gauge you can reshape them, constantly checking the pitch to get what you are looking for. Pat usually rounds and thins the tips along the way.
Carving props is an art and takes time and practice to learn. You have to know what you are trying to achieve and how you achieve it. And you only get that by experimenting based on sound principals. I'm a neophyte at this and I mess with props periodically to learn more. Pat's a master at this.
Offline Chris Wilson
« Reply #6 on: February 26, 2012, 03:13:46 PM »
Leaving the tips square will give the maximum area for thrust  for any given diameter and still keep the low ground clearance that modern stunters seem to love.
Its not the most efficient shape for drag but then again at the revs we run at ( and tip speed) its not that critical.
I have always thought that trimming down the diameter of any prop must go hand in hand with thinning it also.
MAAA AUS 73427
« Reply #7 on: February 26, 2012, 05:34:53 PM »
Prop trimming is particularly fascinating on 4 strokes. I've trimmed a lot of APC,s, and the results are quite profound on the Saito's because, they are not high RPM motors. They tend to be more torquer's.
Case in point, A stock APC 12x6 up against a 13x6 APC trimmed to the exact same diameter as the 12x6. The stock 12x6 beat the trimmed 13x6 EVERY single time. The stock 12x6 out hustled the modified 13x6 in all flight regimes.
Sometimes the results go the other way. It is a lot of fun, and I encourage you to do it.
« Reply #8 on: February 26, 2012, 06:05:49 PM »
Milton,
     it sounds like your average pitch (measured at 70% of the props length) could be changing at the tips when trimmed.
 I would expect a trimmed down prop of same diameter will exhibit a greater pitch at its tips that one that is not trimmed - so your stock 12X6 will be less of a load that a 13X6 that is trimmed down to 12X6 because it is no longer a 6" pitch at its 70% station.
That station or percentage will have moved inwards towards the normally coarser pitch that is found at the hub.
MAAA AUS 73427
Offline Damian_Sheehy
« Reply #9 on: February 26, 2012, 06:16:04 PM »
<Snip>
Interesting topic and I've seen prop trimming mentioned here on SH many times. Like Gil, I'm also interested in the motivation for doing this. The convenience factor is obvious; I have a 13x6 and need a 12x6.
What's the effect on lap time for a trimmed versus untrimmed prop (all other things being equal). Is prop trimming a try and see exercise; e,g, I tried a trimmed down prop and felt I got a much better pattern?
« Reply #10 on: February 26, 2012, 06:19:41 PM »
Milton,
Chris, I see where you are coming from, but I beleive you are mistaken, Pitch at each station is relative to the hub, not to the tip. therefore, 6 inches of pitch at station 10 will always be 6 inches of pitch.
The thing about cutting APC props down is that you loose the blade profile shape, and I believe that the unique shape of the APC is what makes them so solid. Therefore cutting down the tip eliminates a goodly portion of the efficiency of the prop.
I rework a fair number of props, wood mostly, I seldom if ever leave the tip square. In my opinion, its the least effecient shape available for a prop tip,,
« Reply #11 on: February 26, 2012, 06:37:42 PM »
Hi Mark,
            I did say 70% not an arbitrary station 10, and I agree its measured from the hub but it makes no difference (apart from using a descending scale instead of a rising one.)
I stand by what I said, percentage is a function of the whole, change the total of that 'whole' and the position of your percentages will change.
And I thought that the normal meaning of stations was indeed percentages?
Perhaps station 10 is the fixed slot on your pitch gauge?
P.S. The standard for most props stated pitches is actually measured at 75% or 3/4r ( not 70 as I mentioned before) from the hub or 25% from the tip.
Cheers.
MAAA AUS 73427
« Reply #12 on: February 26, 2012, 08:42:00 PM »
Chris,
yes in fact most pitch gauges ( actually all of them I have seen for model use anyway) are not percentages, but instead they are measured relative to the hub center. hence at station 5 or 6 or,,,,,, 6inches pitch will always be 6 inches of pitch regarless. i do not know how that would affect it even if you did figure at percentages though, because the pitch is a relationship of the radius ( from the hub center) to the theoretical forward travel for one revolution, so by cutting it down, you move the 75% inboard indeed, but it will still pitch the same measurment because its related to the actual radius, and theoretical forward movement. What you call that station has no bearing on the physical measurment of pitch at that station.
In fact there is a thread on here somewhere which illustrates this using a degree measuring device instead of a pitch gauge, it gives the relationship of the distance from the hub, to the angle measured giving you the pitch.
of course this ( as has been stated before) ignores the actual camber of the blade airfoil.
as an aside, to prevent thread drift, the tip shape does make a difference, the same way as the shape on the tip of a wing makes a difference in the performance of the wing. as to quantifying that in exacting terms, I am not capable, but I have my pet theories which may or may not be accurate since my observations are of the "feel" variety as opposed to any specific measurement methods.
« Reply #13 on: February 26, 2012, 09:01:05 PM »
Well I suppose we will have to agree to disagree, but consider this, on any prop that exhibits a pitch change like washout towards the tips the measured percentage matters greatly.
Its how all prop manufactures gauge their wares.
A simple gauge like the Prather one merely tells us a figure for any given point and you will not find what overall pitch a prop is classed as without knowing what 3/4r is.
Thanks.
MAAA AUS 73427
« Reply #14 on: February 26, 2012, 09:03:24 PM »
I used to work on props all the time.  Using wood props at the time, it was sometimes necessary to get the right pitch, etc.
I have a ton of Govt. Surplus 12-5 Rev Ups.  I made a bunch of props for McCoy .40s, etc., out of these props.  I generally traced a Top Flite paddle blade on the 12-5 once it was shortened to what I wanted.  Example like making a 10-6 and using a Top Flite 10-6 to shape the new blades.  I also almost always added Phillips entry to the LE of the prop.  I thinned the tips, sometimes even added under camber to the wood blades.  Of course I would correct the pitch.
The purpose of all this was to get a range of props to try on the model to see what worked best.
For my old .40FP, the best diameter of these reworked props seemed to be 10-1/2".  And the pitch liked to be around 5. So I would make a 10-1/2 X 4 1/2, 4 3/4, 5, 5 1/4, 5 1/2.  And the best performer on the plane was duplicated as closely as possible.
Now I have built up a good supply of CF props and using heat to repitch or correct pitch is about all I do! LL~ LL~
BIG Bear
RNMM/AMM
« Reply #15 on: February 26, 2012, 10:57:20 PM »
Chris,
I think I see where we are missing each other here,, in most all of the MODEL props I have measured , the pitch is constant from hub to tip, I beleive based upon my experience with full scale props,, there is indeed some washout towards the tip.
In my experiments, I have played with some washout towards the tip,, ( less measured pitch) As I said, my observations are from the handle so they are pretty limited in overall scope.
Now given that you are assuming there to be in fact washout towards the tip, your comments would be correct. And given that I am basing my comment upon the pitch being constant from hub to tip, My comments are correct,,
so long story short, apples to oranges, we are both right, but in the model world, most times I have observed ( and target) constant pitch from hub to tip, therefore, changing percentages will not affect the pitch of the prop.
« Reply #16 on: February 27, 2012, 02:28:48 PM »
Chris,
Agreed (I like agreeing!)
Strange thing is that all the props I have show tip washout - go figure. ???
MAAA AUS 73427
« Reply #17 on: February 27, 2012, 06:54:05 PM »
Thanks, Bill   H^^
Offline Steve Thomas
« Reply #18 on: February 27, 2012, 10:01:35 PM »
Are we just talking about the blade angle reducing towards the tips here, or something else?
« Reply #19 on: February 27, 2012, 10:25:21 PM »
actually the blade ANGLE will reduce towards the tip just as a function of pitch and radius,, what washout would be would be a twist that results in a reduced pitch towards the tip. as you get further away from the hub, the theoretical pitch will appear to make the blade flatten out towards the tip. what is really happening is that the area towards the tip sweeps a longer distance per revolution, so in order for the pitch ( or theoretical distance traveled) to remain constant the angle of the blade gets flatter towards the tip.. In washout the blade flattens past this and actually has reduced pitch towards the tip.
one line of thinking is that when in level flight the center of the prop ( at a higher effective pitch ) is carrying the plane, when you pitch the plane up and load the prop, the tips will engage and pull the plane,, ( this is what I recall from reading about it)
« Reply #20 on: February 27, 2012, 11:33:25 PM »
Thanks Mark, that's what I thought.
« Reply #21 on: February 28, 2012, 10:26:40 AM »
Seems there's always two different issues around this. The first is the logical, scientific part. Judging pitch, wash out, blade shape, airfoil and station relationships. Like anything else, you develop a theory (I think if I make it constant pitch, I'll get X). And you proceed to carve props.
The other part is flying the thing. When I have a new plane, I take out a box of props. Everything I think has a chance to work. I try them in succession and try to come up with an analysis of what the plane is doing and what I feel at various points. In the end, what I try to come up with is three props that work for various conditions. A dead calm prop (don't use that one much around here), a windy weather prop and a stunt heaven prop.. I am often surprised what what works with a specific plane.
« Reply #22 on: February 28, 2012, 10:44:43 AM »
HI Randy,
I would love to have the practice time to trim my model AND pick the three props you mention..
Unfortunately I have to settle with the prop that works best on that day and fly it when ever! ;D
Of course Randy Smith might walk up and say "You need some more pitch", so I put on a prop that matches but has a little more pitch.......
BIG Bear
RNMM/AMM
« Reply #23 on: February 28, 2012, 02:07:19 PM »
Bill,
With me it's Paul Walker that comes over and looks at what I'm doing. But his response is usually just to shake his head and walk away.
« Reply #24 on: February 28, 2012, 02:12:10 PM »
Bill,
LL~ LL~ LL~ LL~  I don't ever get away that easy! LL~ LL~ LL~
« Reply #25 on: March 01, 2012, 07:55:55 AM »
Thanks for all the responses guys, I'm gradually getting the idea.....now to specifics, I posted this question originally so I could test props in the gap of APC's electric pusher props between the 9x6 EP & the 11x5.5 EP.
I may be wrong, but this seems to be quite a gap.
Thanks, Gil
Gil Mc Millan
AMA 914386
