Hi Dennis:
Thank you for the reply.
The Fox/O.S. nva would only burn off the prime until I rotated the hole in the spray bar to be at bottom of the spraybar. A friend off mine noticed that the hole was on the side of the spraybar and suggested that I turn the spraybar until the hole is at the bottom. After if did this the Fox started and ran on the next flip.
I did use all of the methods that you had suggested regarding installation of a nva. I have been doing it for years and it has always worked very well.
Perhaps the bullet, round ball etc. and a spraybar was not the best anaology to use in this case. It may be comparing aples to oranges. In pointed bullets, peoople have attempetd to lessen the drag by using a boat tail design. The navy tried to use shell that had a hole the full length of the projectile to lesson the drag caused by the base of the bullet. This did not work. I think that boat tail and hollow shells only work at subsonic velocities. Above this, there is just to large of a shock wave in front of the projectile.
After studying race car dynamics, it appears that most of the drag is created by the front and rear of the car. I can not remember reading anything about reducing drag caused by the side of the cars. Again I may be confusing different discilplines of aerodynamics.
In any case, thanks again for taking the time to give me some information.
Stay well my friend,
Frank
