One can get technical , or barbaric , on these .
Some early large thread OS muffler ' pressure take off ' nipples had a LARGE bore hole .
Some aerobatic flyers like a SMALL HOLE , like 40 thou. or a RESTRICTOR TUBE of that bore , in the pressure line .
Or a fine bore ( 1/16 max . ) uniflow or vent pipe , in the tank .
Zee nipples , as they only go through maybe a 1/16th of metal , can be used to thread the hole , if you get it ' just right ' & the metals soft .
A tap vaugely similar helps ! Useually using the TAPERED part , just enough to start the thread right through , and START the nipple firmly .
The Melability will form the thread . If you dont break a plated brass nipple !
BRODAK do Std Nipples . Some are nutted and only require a HOLE .
In fact if theyre shanked youre stuck with ' just a hole ' . They seem to stay put .
If been obliged
to ' fredem ' this way . And only broken one or two nipples . Coarse threads easiest . Usually threadem close to correct & use the nipple to reform the thread. Lubed . Dont Tell Anyone Tho.
Smacks of butchery , like when it tears out the hole .
