Guys,
As an experiment, I just converted my electric powered profile Roadrunner back to glow power to see if there were balance issues causing it to hunt. Long story short: the answer is "Yes". The plane flies steady as a brick on a string with the glow power and I'm not sure I want to take it back to the AXI electric.
I swapped the AXI for an OS LA46 because 1) the Ehlen motor mounts are drilled the same as the OS LA/FP series engines, and 2) I had one laying around.
Personally, I have NEVER been able to get one of these POS engines to run right and will open the discussion up to other ideas.
Would an FP 35 be enough to handle a 610 square inch, 47 ounce stunter? (I have one of those laying around, also.)
Many engines don't perform right on their side. How about the PA engines?
Open your minds. I need help.
Ron
