  • July 04, 2025, 08:06:01 AM
Author Topic: Profile Engine - What's Best?  (Read 2964 times)
Offline Ron King
« on: September 19, 2006, 12:13:55 PM »
Guys,
As an experiment, I just converted my electric powered profile Roadrunner back to glow power to see if there were balance issues causing it to hunt. Long story short: the answer is "Yes". The plane flies steady as a brick on a string with the glow power and I'm not sure I want to take it back to the AXI electric.
I swapped the AXI for an OS LA46 because 1) the Ehlen motor mounts are drilled the same as the OS LA/FP series engines, and 2) I had one laying around.
Personally, I have NEVER been able to get one of these POS engines to run right and will open the discussion up to other ideas.
Would an FP 35 be enough to handle a 610 square inch, 47 ounce stunter? (I have one of those laying around, also.)
Many engines don't perform right on their side. How about the PA engines?
Open your minds. I need help.  %^ %^
Ron
Ron King
AMA AVP District 4
Wannabe Stunt Pilot since 1963
 Amateurs practice until they get it right; Pros practice until they cannot get it wrong.
Offline Leester
Re: Profile Engine - What's Best?
« Reply #1 on: September 19, 2006, 12:41:56 PM »
With that size plane you would probobly be better off with a 40 or better. From what I've heard the PA 40 would be the cream of the crop. If you want to match up mounting holes the FP or LAS 40 would do it.
Leester
ama 830538
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #2 on: September 19, 2006, 01:57:01 PM »
Ron, no reason the LA 46 shouldn't run fine.. If it was an LA 40 I would have my doubts but the 46 is a different animal. Use an APC 12.5 X 4.5 prop with 1/4 inch taken off the tips and 10-20 or 22 50/50 fuel. Have had and seen many of them run great on profiles set up this way...
Offline Ron King
« Reply #3 on: September 19, 2006, 03:55:26 PM »
Use an APC 12.5 X 4.5 prop with 1/4 inch taken off the tips ...
Bob,
I cannot find that prop in the APC catalogue. I've tried the APC 11.5 x 4, 12.25 x 3.75 (regular and clipped), and the APC 11x 5. All worked okay, but all seemed to like straight 2-stroke running.
BTW - I have a NIB Double Star 54 and have been toying with the idea of trying this engine. It's actually lighter than the LA 46 (that's not saying much, lots of engines are lighter  n~) and since it was actually designed for CLPA, maybe it will run better. I'm still thinking...... ~^
Ron
Ron King
AMA AVP District 4
Offline Bob Reeves
« Reply #4 on: September 19, 2006, 04:58:31 PM »
Sorry was going from memory and screwed up.. you are right 12.25 x 3.75 cliped.. Yes it runs in a rich two but it's solid, realiable and will not run away...
Hey if you need someone to break in that Double Star and see how it stacks up against a good ST 46 I have just the airplane... If it works I will buy you a new one and break it in or send yours back all ready for whatever you want to put it in  :)
Offline Ron King
« Reply #5 on: September 20, 2006, 09:32:31 AM »
Bob,
Thanks. I had actually started to mount the DS 54 in the Roadrunner, but will try that prop again and see if I can make it work.
I'm also wondering if maybe I'm part of the problem.  '' I am deaf in one ear and have trouble hearing certain audio tones in the other. Since we pick up a lot of our engine's info by ear, it's hard for me to differentiate between a "fast four stroke" and "wet two stroke". My engine may be running just like yours, but I cannot tell.
I went and measured the Double Star engines and even though they have the same bolt pattern as the ST, both the DS 50 (1/16") and the DS 54 (1/8") are longer at the front end. You would have a huge gap between the spinner and nose ring. I guess the phrase "drop in replacement" is somewhat true, but not totally accurate.
Take care,
Ron King
AMA AVP District 4
« Reply #6 on: September 20, 2006, 09:59:37 AM »
Ron, if you aren't sure of what you are hearing, get a tach.  Even the cheapy Hobbico ones work well enough.  Let the engine warm up for 30 sec or so.  Run it up to peak rpm, then back of a specific amount.  On one of my LA 25's richening it up 1000 rpm does the trick.  Other engines may vary.   A tach is a bit more reliable than the ears.
Certain engines are fun to set by ear.  The Brodak 40 hits that really deep, throaty 4 stroke, that is hard to miss.  The ST 46 is similar.  They usually have a very easy to spot 4 stroke setting that will usually work well in the air.
Offline Bob Reeves
« Reply #7 on: September 20, 2006, 10:03:49 AM »
Hi Ron,
Hey it was worth a shot :) Thanks for the mounting info.. Would sure like to know how that 54 runs.. If you get yours going let me know your opinion. If I was sure it would be worth replacing the ST 46 I wouldn't be against reworking the nose.
Take care
Bob
Offline Ron King
« Reply #8 on: September 20, 2006, 11:39:24 AM »
Phil,
I agree and actually I use a TNC tach when I'm running my engines. The problem is the ground setting on the LA 46 doesn't equate to an "air" setting that I'm used to hearing. Right now, the engine starts and seems to set easily, then speeds up soon after launch. I think it's running too fast, but maybe it's in that "wet two stroke" mode of operation and I'm just missing it. I see a trail of blue smoke, but I'm just not sure about the run. If that's what it's supposed to do, I'll just put on longer lines and learn to live with it.
I also like those throaty four stroke sounding engines. They are easy for me to set and fly. I tried to swear off dealing with converted RC engines (like the OS LA series), but the challenge is too tempting. If I had any brains, I would convert this LA 46 into an artificial reef in the aquarium and would stick to "real" CLPA engines.  <=
Ron
Ron King
AMA AVP District 4
« Reply #9 on: September 20, 2006, 08:20:21 PM »
Ron
Hi Ron,
Sounds like the best idea to me since you can get about anything you want to put in it!  **) **)
I just don't have the time to "chase" an engine run and still get ANY practice in.  AND, I have found what a real stunt engine run is supposed to be.  I got a feeling that way too many have not.  :(
Bill <><
Offline Ron King
« Reply #10 on: September 21, 2006, 06:35:22 AM »
Bill <><
Amen to that, Bill.
I also think I know how the engine should run and this one is (was) driving me to distraction. Last year, I told Dave Reyes he could break my arm if I tried to play with RC conversions again. Unfortunately, he could not drive over here fast enough to keep me from wasting a whole week on this nonsense.  ~^ ~^
The issue with the profile Roadrunner has now been settled. After much discussion between me and my cats, I bit the bullet, sawed off 1/8" of the nose, and plopped a nice Brodak 40 in the nose. Not only do I have a "for real" CLPA engine up front, I saved over an ounce of weight.
My 47 ounce profile Cardinal flies great with a Brodak 40 up front. I have no doubts a 610 square inch 46 ounce profile Roadrunner will do likewise.   <=
I am a Happy Camper again.
Ron
Ron King
AMA AVP District 4
Offline George Waters
« Reply #11 on: September 21, 2006, 07:07:33 AM »
Ron Glad to see you got your problem solved with the b 40. My flying partner has two la 46 engines. The first one was a controline engine to start with, the second was an rc conversion. #1 was perfect from dayone,#2 was always trying to run away after launch. We tore both engines down and found that the head on the rc motor had a much smaller combustion chamber than the cl motor. One extra gasket and they both are great. He runs 11/5 prozinger or 11/5 or 11/6 ma props 10/24 fuel half castor half synthetic. The planes are an arf cardinal and arf p40. Hope this helps. George
« Reply #12 on: September 21, 2006, 06:13:07 PM »
Amen to that, Bill.
Ron
Hi Ron,
I believe that the Road Runner will be even better with the B-40.  I don't believe it is as "draggy" as the Cardinal.
Bill <><
