  • July 03, 2025, 08:09:48 PM
Author Topic: problem to adjust fox15 bb/cl  (Read 856 times)
Offline Dick Kultner
« on: August 20, 2009, 09:24:28 AM »
 hello, i try to adjust my new engine,its hard to do it some tiems its to lean or to ritch the needle valve are only half turn out.thanks. ,swede,
Re: problem to adjust fox15 bb/cl
« Reply #1 on: August 20, 2009, 10:04:31 AM »
Teflon tape on the threads or a short peive of fuel line over the threaded portion.  Make sure spray bar hole is in correct position.  Have fun,  DOC Holliday
Alan Hahn
« Reply #2 on: August 25, 2009, 07:28:36 PM »
It does take some time to break in the Fox15 since it is an iron piston/steel sleeve. Maybe that is the problem.
Mine are all sweet running engines.
Offline fred krueger
« Reply #3 on: August 26, 2009, 11:27:05 AM »
I've seen this needle sensitivity problem with too little oil in the fuel.  Make sure you are running at least 20% oil.  All castor is preferred as this is an iron piston engine.
Fred
